I just got my ideallume backlights and installed them. I haven´t yet calibrated the backlights but I dimmed them down pretty much all I could. I only have a 32" and I still get tons of backlight. Gonna get DVE to try and calibrate it a bit.
That's a lot of light for such a small TV. However, LCDs tend to run brighter and you may end up needing the extra illumination to put the right amount of illumimation on the wall (10% of peak white). Another way to reduce the light, after rotating the baffle tubes all the way around, is to rotate the whole fixture around to block more light from reaching the wall.
Feels like the image somewhat feels brighter then before due to the backlight which I thought would be the other way around?
If you mean versus having the room lighting on, yes it will likely appear brighter in a darkened room.
I also use the tv as computer monitor so it being better for the eyes is a big plus if it turns to be true
Of course it's true!
Though it´s not all that far from grey after all.
Sounds decent enough for a 90% kind of guy.
Should I set it to 6500 too if it isn´t already
Only if you want better image fidelity.
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
"Advancing the art and science of electronic imaging"
ut of the box" performance?
