Originally Posted by
chas_w
Isn't the Sierra 1 center (horizontally positioned) the same height as the 340SE center?
Yes, and it has the same depth, as well, which matters somewhat because it will be tilted.
Drew888
My concern (and question) is can I install the 340-SE center and will it blend well enough for the Sierras? I could use a Sierra 1 as a center but then couldn't angle it up toward our siting position.
You can angle it exactly the same as the 340SE, so use a Sierra-1 center.
Drew888
A 340 SE at 7.5" could be angled up a bit though I'm still not sure it's enough. Currently I have a Paradigm cc170 in there now and it's angled perfectly (yes this is a big step up for me and I'm excited).
How much is your CC-170 tilted upward? Tell me that (height in inches at the very front of the speaker), and I'll tell you how far forward you'd have to move the Sierra-1 in order to match it.
Running through some sample numbers ahead of time, the bad news is that you'd probably have to move the Sierra-1 so far forward that it would lose its balance. However, the good news is that the most your CC-170 can be tilted upward now is probably less than 10 degrees, which should be well within the Sierra-1 center's vertical listening window--in short, you don't even have to tilt it. By all means do so, as it helps avoid some floor-bounce in your case and it's better than nothing, but your new center should sound fine regardless.
Drew888
My other question is in placement of the Sierra 1's. How far forward of the TV should they be?
It doesn't take much, and not so far that they'd be in front of the center speaker.
EDIT: I just noticed that the Sierra-1's measurements page is messed up, showing exactly the same graphs as the vertical bookshelf version's page.
What I said earlier should still apply, though.
