AVS › AVS Forum › Gaming & Content Streaming › HD Radio › HD Radio signal range
post #1 of 9
I saw this posted over at the NYRMB by Scott Fybush in response to a question about signal range. He offers a good summary that answers one of the frequently asked questions about HD Radio, so I thought it deserved to be posted here for future reference:
There are four basic classifications of licensed FM stations : A, B, C and D. On average, the range of their analog (non-HD) signals are as follows:
Class A goes about 25-30 Miles
Full Class B goes about 50 Miles
Full Class C goes about 70 Miles
Class Ds usually go 5 miles or less.
Class B1s go about 30-40 miles
C1s go about 60 miles.
C2s go about 40-50 miles
C3s go about 30-40 miles
[Scott]:
Those are decent rule-of-thumb figures for usable reception on a good radio, albeit perhaps a little on the generous end for a class A (especially the older 3 kW class As, of which there are still many in the northeast).
But those numbers also assume that the station in question is operating with full spacing to other stations in its area, which is almost never a viable assumption in the crowded northeast. Nearly all the FMs in the NY metro area are short-spaced, some to a small degree, others massively so. (Think WCBS vs. WBEB on 101.1, where WCBS-FM becomes unusable as little as 30-35 miles from Empire in the direction of Philadelphia.)
Those numbers also assume analog-only operation. IBOC sidebands on short-spaced stations further exacerbate the problem. WCAA on 105.9 already has IBOC. I don't think WBLI on 106.1 does, but when that happens, it will create even more unusable area between the two signals over Nassau County.
In practice, for good digital (HD) reception, the magic signal threshold appears to be somewhere in the 65-68 dBu range, just shy of the 70 dBu that the FCC considers "city-grade."
A rough rule-of-thumb on those distances, again assuming full spacing and maximum antenna height for the class, goes like this:
3 kW A - 8-10 miles
6 kW A - 10-12 miles
25 kW B1/C3 - 18-20 miles
50 kW B/C2 - 25-30 miles
100 kW C1/C0 - 30-35 miles
100 kW C - 35-40 miles
For a class D station, you probably want to be able to see the antenna...
post #2 of 9
My HD range is an Amana. But I hear the Kenmores are nice
post #3 of 9
Sounds about right. I've found that the HD tends to go about 1/3 to 1/2 the distance of the analog...
That needs to be stronger ;-}
post #4 of 9
I live EIGHTY MILES from my favorite HD stations, and they come in FINE with my Accurian, and an INDOOR Magnum Dynalab SR100 antenna. Listen for yourself http://www.theproductionroom.net/hd.wma
If 80 miles is "1/2 to 1/3" of their analog coverage, these stations must have MONSTER signals!
post #5 of 9
It could also be favourable conditions allowing the signal to find its way to your house better. Or maybe they just have an awesome transmitter.
I get about 30-40 miles from the Philly stations and start to lose them, but can get up to 60 on analog. Of course, there's lots of hills and pseudo-mountains along this route (and my car's antenna sucks)
post #6 of 9
Most consumers will not make any effort at all to upgrade their antennas. Can't assume the radio will work any better than it will with supplied antennas.
post #7 of 9
What radio stations really need to educate listeners on is that the most important part of any radio IS THE ANTENNA! Get as good a one as you can afford, and GET IT AS HIGH AS POSSIBLE!
As for my location, I live in the foothills of northwest North Carolina, near the Blue Ridge parkway. There are mountains all around. It's multipath hell! And I'm not talking about a single transmitter, from a single direction. Stations to the south (Charlotte/Davidson...about 80 miles away) come in just as well as those to the east (Winston Salem/Greensboro...about 60 miles away). The recording I posted is of MULTIPLE stations in MULTIPLE cities, from different points on the compass. HD just works better than a lot of people think.
Hell, people accept that they need a properly oriented antenna for satellite tv or radio. OF COURSE THEY NEED ONE FOR HD, or even good terrestrial radio. I firmly believe that a huge percentage of listeners don't even know what fm stereo sounds like, because they use such crappy antennas (wire bunched up, tossed behind the equipment rack).
post #8 of 9
Living 60 miles east of Philly in Lancaster Pa., The antenna is pointed East towards Philly and I can pick up their analog signal, I also get the digital HD signal. I keep hearing people talking about HD fade. The only time this was a factor was when I was picking up a station from the back side of the antenna. The analog was there, but the HD was in and out.
I am about 80 miles from Baltimore. When I pointed south I get the strong stations, both analog and HD digital, any other direction I get neither.
I am 100 miles from Washington DC. Both analog and HD fade in and out.
post #9 of 9
Ah fmdxer, lucky you with a pointable antenna. That doesn't work so good in the car. I head out to Lancaster every weekend, can pick up the HD pretty well up until the WalMart on route 30 (at the end of the Exton Bypass), past that it starts to flake out on me until I get to the really big hill where I lose it.
  Back to Forum: HD Radio
