Originally Posted by Ace_of_Sevens
@cosmogeek: component doesn't have offline signaling to say what teh aspect ration is. You'd have to manually change it no matter what TV you have unless you have a player that's doing the changes itself.
No luck on the QAM. I just scanned a third time, and as before there are no QAM channels coming up.
Have you actually tried it on this set? I think it is broken. It is adding the bars to the sides of my picture when it shouldn't be.
It is most certainly NOT functioning the way I expect and have experienced with the other 3 16:9 tvs I've owned nor the many others I've helped other people setup.
The only way I could get it to get it to fill the screen (not have the bars on the sides) is to use the fill mode, which is not correct since it chops off a huge portion of the top and bottom of the picture.
It looks like the aspect ratio is correct for about a half a second then the screen switches and the bars get added to the sides.
Ok I just tried it and as soon as I switch my xbox360 to 480p it adds the side bars when set to "Normal". I thought maybe it was my old dvd player so I tried the xbox just to make sure. The Fill mode chops off a non-trivial amount of the top and bottom of the screen. If this was working correctly it wouldn't have to since the image is the perfect shape to fit the screen in the first place.
EDIT:
I just submitted an online help thing to westinghouse describing this problem. I'll report back what I hear from them.
