I have a situation where I am not really going to be able to do triangle bass traps in the corners due to space issues. Does this matter?
At the front on either side of the screen I can fit in traps that would be about 15" wide by about 12" deep and running from floor to ceiling. I am thinking of using Roxul Safe n Sound insulation since I have some left over. Will this work?
At the back of the room I have other challenges. I have a side window that butts right up against the back wall. This will make it basically impossible to build a trap on that side. I could build a trap on the other side but will this work if I only have one in that corner and not the other?
