Originally Posted by
Mark Petersen
Dynamic Iris Performance Summarized:
Much has been written about dynamic iris performance from a
subjective standpoint...What we have found is that the contrast performance of
a DI is far more complicated than these perspectives and we can summarize the key points here:
Final Summary:
"Using this framework can help people
adjust the performance parameters that affect contrast to better suit their tastes."
Subjective ... complicated ... so adjust to you taste...
I agree and would add there is not even a clear way to calculate and select even the screen size. Its just too complicated as there is no one good or simple answer.
Below are the many Sony VW50 brightness outputs according to measurements from the SMPTE brightness thread.
Note: this is the first and last time that I'll expect to read this thread as it just too complicated. It unintentionally reinforces that dynamic iris is an unpredictable band-aid solution.
Sony VPL-VW50 Screen Calculations for 12fl Brightness & 1920*1080 Best Viewing Distance
Measurements are from WSR magazine issue 115. The calculations are being provided because the new Sony VPL-VW40 is supposed be similar to this model.
We are taking the long route here with four screen sizes per lamp setting, as these are the boundaries from which the auto iris adjusts itself, depending upon the particular frames signals content. In other words the Auto iris varies from best contrast to best brightness while also introducing compression at the top. Take you pick of one or the other, but never the two simultaneously.
The review does not take into account the 50% reduction in brightness due to bulb aging for selecting a screen size. We do here
Best Contrast, Worst Brightness (Auto Iris mode = off)
Sony VPL-VW50, low lamp, minimum lens aperture, 1.0 screen gain
sqrt(14*234*1.0) = 57 inches maximum diagonal screen size, 5.7ft best THX viewing distance
Sony VPL-VW50, low lamp, minimum lens aperture, 2.5 screen gain
sqrt(14*234*2.5) = 90 inches maximum diagonal screen size, 9.0ft best THX viewing distance
Sony VPL-VW50, high lamp, minimum lens aperture, 1.0 screen gain
sqrt(14*361*1.0) = 71 inches maximum diagonal screen size, 7.1ft best THX viewing distance
Sony VPL-VW50, high lamp, minimum lens aperture, 2.5 screen gain
sqrt(14*361*2.5) = 112 inches maximum diagonal screen size, 11.2ft best THX viewing distance
Worst Contrast, Best Brightness (Auto Iris mode = off)
Sony VPL-VW50, low lamp, maximum lens aperture, 1.0 screen gain
sqrt(14*432*1.0) = 78 inches maximum diagonal screen size, 7.8ft best THX viewing distance
Sony VPL-VW50, low lamp, maximum lens aperture, 2.5 screen gain
sqrt(14*432*2.5) = 123 inches maximum diagonal screen size , 12.3ft best THX viewing distance
Sony VPL-VW50, high lamp, maximum lens aperture, 1.0 screen gain
sqrt(14*652*1.0) = 96 inches maximum diagonal screen size, 9.6ft best THX viewing distance
Sony VPL-VW50, high lamp, maximum lens aperture, 2.5 screen gain
sqrt(14*652*2.5) = 151 inches maximum diagonal screen size, 15.1ft best THX viewing distance
Notes
1) reviewers state the picture quality is superior with the auto iris engaged
2) auto/dynamic iris mode makes exact screen selection painful as the size falls somewhere between the highest contrast or highest brightness sizes. As a rule, higher contrast equates to better picture quality. Each owner must select some screen size. Or as an alternative, choose a projector which does not require a dynamic iris to achieve optimal picture
