AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Linksys router (BEFSR41) streaming
post #1 of 5
Anyone know of the right settings to get the PS3 streaming to work with the Linksys router (wired) BEFSR41?
I've tried everything to no avail.
When connected directly (CAT6 PC <-> PS3) it works fine, using WMP11. When connected thru the router they can't see each other at all.
post #2 of 5
In your linksys settings. Under security tab. Enable filter multicast.
post #3 of 5
THANK YOU that's all I needed to do (after I enabled UPnP ..) works great.
post #4 of 5
Hmm. Did you enable UPnP in your routers settings? It should still work w/out having to enable that. Have you tried for kicks?
post #5 of 5
Yes I enabled it yesterday, but it didn't help.
It's working now though, so I'm not going to mess with it.
  Back to Forum: PlayStation Area
