AVS › AVS Forum › Display Devices › Display Calibration › Basic Guide to Color Calibration using a CMS (updated and enhanced)
Basic Guide to Color Calibration using a CMS (updated and enhanced) - Page 54
post #1591 of 1810
And the white point?
Attachment 169475
post #1592 of 1810
Attachment 169475
Sorry, Not sure what you mean. I do check white when doing a run but I see the missing data. All my runs are missing the white delta e numbers but I have no idea why!
thx
bob
post #1593 of 1810
I meant what white point are you using for a reference?
post #1594 of 1810
I try to remember to set it at D65 but it doesn't save in the preferences.
I could have forgot before this run. Would that make a difference?
thx
bob
post #1595 of 1810
I think so. Open your file, play with the white point reference setting, and see how your DE changes.
post #1596 of 1810
No difference.
thx
bob
post #1597 of 1810
Strange, it did on my end. What version HCFR are you using, and on what OS?
post #1598 of 1810
Version 2.0, Vista 32 bit.
What is strange is when I go to preferences and check the D65 box, it won't let me apply (grayed out). Because it's already selected?
bob
post #1599 of 1810
Originally Posted by spongebob View Post
No difference.
thx
bob
Sorry, changed to D75 or D55, big change on chart.
bob
post #1600 of 1810
So what does the dE become with D65 as the reference?
You could try upgrading to 2.1.0... but for the record, I'm running 2.0.1 here at work...
post #1601 of 1810
My first charts are correct @ D65. I couldn't change to D65 cuz it was already set there LOL.
What about colorspace 1 or 2 on the Kuro? Would changing that give different RGB/CIE numbers?
thx
bob
post #1602 of 1810
I would probably give different numbers, but what the display is putting out isn't as much the problem as why you're getting different dEs out of HCFR than the rest of us...
do you have another file open you're using as a reference measure?
post #1603 of 1810
No other files open. have closed and opened HCFR many times, same numbers. Any other settings that could be it?
BTW, what de are you guys getting for magenta, again?
thx
bob
post #1604 of 1810
Originally Posted by TomHuffman View Post
I don't know what you are looking at.
I'm looking at this!
bob
post #1605 of 1810
Both cyan and magenta are incorrectly reported. They should be 2.8 and 7.4, respectively using CIELUV against a Rec. 709 target. RGBY are correct.
I seem to recall that an early build of HCFR had this error. This is an HCFR-specific problem.
post #1606 of 1810
I'm downloading 2.1 right now. Was running 2.0.
Thanks, Tom
bob
edit: 2.1 Fixed it !!!
post #1607 of 1810
Tom,
What is the Yx value on the spreadsheet? I'm trying to learn about CIE94, etc and want to enter my HCFR readings into the chart. What is the HCFR equivalent?
thx
bob
post #1608 of 1810
Hey Tom, don't want to derail your thread, but I was wondering what your take is on local dimming lcd's. Calibrate on or off? I understand you can use full field patterns on the AVS disc, and once you calibrate with it off or on, you have to leave it that way. I'm coming to the opinion that LD on looks real good, but kills detail.
Have you calibrated any LD sets?
post #1609 of 1810
Yes, with mixed results. Don't really have any advice to give.
post #1610 of 1810
Thanks. What I've found, is that overall, I prefer the LD on, but it definitely has its issues. IMHO, this keeps Plasma as the top tech. The Regza is real hard to dial in with LD off, and deltaE's under 3 are hard to come by. Much better with it on.
I goofed around last night and found I was able to get more light output with a lot less backlight and contrast, by turning off the scanning backlight and it also allowed for a much straighter gamma line at 2.32. Dunno why the scanning backlight would effect gamma(part of it is prob the lower backlight and contrast), but it does. I'm amazed at how diff features effect different things between the brands and models. I feel for professional calibrators.
post #1611 of 1810
You are too modest Tom.
Using ChromaPure and a Chroma 5 to calibrate the 55LH90 the results are very good. More importantly OTA and even CATV look great on my set.
http://www.avsforum.com/avs-vb/showp...&postcount=331
This calibration was done with LD on and field patterns using the ChromaPure pattern disc playing on a Panasonic S97 SD DVD player.
post #1612 of 1810
It doesn't look like this has been Posted anywhere yet , but for those of you interested in Poynton , here is a Link (pdf) of the first Article that SpectrCal will be hosting...
http://storage.pardot.com/2742/29527...r_Mar_2010.pdf
Enjoy
Scott.................................
post #1613 of 1810
nt!, kicking it old-school! Next up stilb.
post #1614 of 1810
Hi Tom,
what do you think of the "75% saturation/100% brightness" method to set primary and secondary colors? Basically that's aiming to hit the 75% saturation point for colors instead of the usual 100% saturation point.
http://www.avsforum.com/avs-vb/showthread.php?t=1134710
It makes great sense to me if the display colors are grossly under-saturated at 25/50/75% saturation points.
For example, I calibrated my Samsung A650 plasma using the conventional method of 100% saturation/100% brightness colors (of course after setting brightness, contrast, gamma, grayscale, etc), but was never really happy with the results. I somehow came across the thread linked to above and learned about "75% saturation" and "saturation-luminance" (big thanks to Dan's excellent spreadsheet).
I was quite surprised to see my plasma's performance here. The 25/50/75% saturation points for most of the colors were well short of the mark. Here is the color gamut AFTER I tried my best to use 75% saturation method. The Samsung primaries and secondaries can't be saturated any further, so that's about as good as it gets.
Perhaps more disturbing are the saturation-luminance measurements I obtained. Here are the charts for RED, which are the most problematic (and noticeably incorrect) color. Below are 2 charts. The main color control is set to default in both. In the first chart, the RED brightness is default. In the second chart, the RED brightness (only) was lowered using the Sammie's 3D CMS.
The effect I see of adjusting red brightness is to get the 100% red saturation point close to the correct brightness. But look at 75% saturation and lower! They are too bright. Is there any way I can get this *entire* curve to lie reasonably flat and close to the reference line?
post #1615 of 1810
Not sure what I think. I guess that it seems reasonable to me to choose any CMS setting that does the best job possible of minimizing error for as many data points as you have. Taking saturation and luminance readings from multiple levels just gives more data points. Of course, what you are likely to find is that no one CMS setting will get the results right for all points, so it is a matter of compromise.
post #1616 of 1810
Not sure what I think. I guess that it seems reasonable to me to choose any CMS setting that does the best job possible of minimizing error for as many data points as you have. Taking saturation and luminance readings from multiple levels just gives more data points. Of course, what you are likely to find is that no CMS settings get the results right for all points, so it is a matter of compromise.
But isn't 75% more "real world" than 100%?
bob
post #1617 of 1810
I can't think of any reason for why a particular shade of red would be more "real world" than another. In fact, the entire Rec. 709 gamut is not particularly "real world" insofar as it excludes many higher saturation colors entirely.
post #1618 of 1810
bob
Do you mean 100% saturation/75% stimulus or 75% saturation/100% stimulus? I believe 100% saturation/75% stimulus is better than 100% saturation/100% stimulus since 75% stimulus produces about 50% light output, which is closer to most content than 100% light output.
post #1619 of 1810
Maybe what he meant is that in most content 75% saturation is seen more than 100% stauration. Anyway, with my LG 47LH90 I had to choose between getting either 100% saturation right and getting 75% saturation and lower right. Adjusting for a correct 75% saturation response produced the smallest error at the remaining staurations. And, assuming that there was more content at 75% and lower made it easier to accept the tradeoff
post #1620 of 1810
That's how I understood the post. I can only repeat my reply. 100% saturation simply means a particular shade of red in the Rec. 709 gamut. I can think of no reason why THAT shade of red would be any more or less represented in the real world than other shades of red, 75% in particular. Think of the red one sees in a red rose. My guess is that that's more saturated than 100% Rec. 709, not less.
Using 75% as a target to minimize dE errors across the range of saturations within the gamut is a perfectly reasonable approach, but that strategy--even if successful--says nothing about what level of saturation is more typical in available content.
