Hi all,
Is there any preference as to whether one should select a device to output HDMI RGB as opposed to component HDMI YCbCr (providing the device supports both - see PS3, oppo 970hd etc), when calibrating a system?
If so what is the compromise (if any) with some source devices which only output HDMI YCbCr (ie a Sat Reciever, tosh HDDVD hd-e1 (or ax1 in US I think) etc)
My thinking is since most of the digital displays will output anything (over HDMI) as HDMI RGB, it is better to have the source outputting HDMI RGB too (?) avoiding any color space issues that come from sources mis-matching SD ITU 601 to HD ITU 701 when using HDMI component (thinking of upscaling/upconverting players here). But is it the case?
Many thanks,
Kostas
Many thanks,
Kostas
