I knew that this would provoke a spirited response. The dE difference varies according to the way you measure dE. Here are the averages:
dE(uv) 1976: 6.5
dE CIELAB 1976: 5.6
dE CIELAB 1994: 1.9
To put this in some perspective, I did a survey of several modern digital displays some time ago using dE CIELAB 1976 and the BEST performing display AFTER applying the included CMS revealed an average dE of 4.7. The worst was 32.5. The middling performers were in the mid-teens. Furthermore, a lot HD video is apparently mastered with monitors that use SD phosphors.
Given that reality, I guess all that I was saying that it is hard for me to get too worked up over the differences between SD and HD color spaces. I've looked at the numbers and I've seen nothing that would cause me to change my mind. When we get to a time when displays are a lot more color-accurate than they are now I'll certainly reevaluate.
On a side note, the one real profound difference between dE(uv) and dE CIELAB is how they treat red and blue (they seem to treat green similarly). The difference between:
0.630, 0.340, 0.212
and
0.640, 0.330, 0.213
is 5.8 in dE CIELAB, but 12.6 in dE(uv). For blue, the difference between
0.155, 0.070, 0.087
and
0.150, 0.060, 0.072
is 9.0 in dE CIELAB and 4.3 in dE(uv). It looks like dE(uv) perceptually weights differences in Lightness less than CIELAB.
dE(uv) 1976: 6.5
dE CIELAB 1976: 5.6
dE CIELAB 1994: 1.9
0.630, 0.340, 0.212
and
0.640, 0.330, 0.213
0.155, 0.070, 0.087
and
0.150, 0.060, 0.072
