No, it isn't. I'd get the CA 813 Light meter and point it towards the lens.
Originally Posted by awssvtt
2. For contrast setting, I got around 4fl with High Contrast Setting (IRIS). I could not increased the value of Y at 100IRE (increase fl) even at Max Contrast Setting. So the only option is to change the Z12k setting to High Brightness but at the expense of Contrast. Thus, a new bulb is needed only at aroung 500 Hrs. Is that the only option that I have?
Again, use the CA 813 to measure light output. Place at the screen plane facing towards the lens.
I can only tell you what I do. To adjust Contrast and Brightness, use the Contrast and Brightness controls.
