Hi folks, hoping you all can help me out. I recently ordered
the high powered emitter last week from 3dglassesunlimited.com. Granted I only ordered the emitter and no glasses, so this may be incomplete but I was thinking that the process should still work.
I am using the emitter with the Samsung HL-T7288W and the "slim" PS3 with updated firmware (4.11 I think it is). The PS3 is directly connected into the TV HDMI port. I did as the
instructions said to do , the TV recognized that the emitter was present and allowed me to switch the options between ON-STD GLS or ON-INV GLS in DLP 3D/Dual-View menu. The power light on the emitter turns on and I can see the screen change 3D modes.
Seeing that emitter was on, I went into the PS3 display settings to activate the 3D function as instructed in these directions:
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
When the PS3 scans the available display resolutions, it should pick up but doesn’t that the TV is in 3D mode. It seems likes it the TV turns off the 3D function when it scans for the resolutions. So it doesn’t give me the option of setting the screen size like it does in step #5.
I also connected an LG 3D blu ray player from a bundle I got in November, which I know works displaying 3d, to see if it would get the Samsung TV displaying but no dice. It will boot up the disc but the menu screen is the default "you need a 3d tv to display 3d content."
Any thoughts to what I am doing wrong?
