AVS › AVS Forum › Display Devices › Screens › What screen would you put in this room?
post #1 of 7
The room is 22x17 rectangular with a 10' ceiling. no windows. painted dark gray and black. I am looking at maybe buying the panasonic PT-AE1000U pj. What size screen and what type and brand would you suggest? I have 100% light control in this room so will just about anything work? I'd like to spend around 500 or less on a screen if possible. I just need the screen to mount to the wall, no roll ups or anything liek that.
thanks.
post #2 of 7
If you buy a commercial screen, rollups are usually cheaper, cost less to ship and are easier to setup (no setup required, just put up to screws and hang).
I keep my rollup screen down 98% of the time.
I too have a dedicated (pitch black room) and love my highpower. Yeah, it's bright, but I like it bright.
depending on your seating, I'd probably opt for 119", but I could see trying to go a bit bigger (126-135").
post #3 of 7
What is Outdoor Theater?
post #4 of 7
http://www.avsforum.com/avs-vb/forumdisplay.php?f=159
post #5 of 7
Id really like a regular screen that I can attach to the wall. Any color recomendations or site recomendations? Id like to buy one soon.
post #6 of 7
Check out the Carada screens (not sure of price) but also the Elite Cinetension screen
post #7 of 7
Stewart FireHawk G3 would be the best you could do with this projector. Not the cheapest, but the best.
  Back to Forum: Screens
