AVS › AVS Forum › Audio › Receivers, Amps, and Processors › denon avr 2307 volume issue
post #1 of 8
never mind figured it out thanks
post #2 of 8
After auto calibration???
If so, try turning down the sub on the actual sub and redo it.
post #3 of 8
no sub hooked up. and its turned off in the menu..
post #4 of 8
What are the individual speaker volumes at?
post #5 of 8
how do i check that
i think they are all at 0db should i crank them all up to +12?
post #6 of 8
Either on your reciever's digital display or the on screen menu it will show you each speakers individual volume ranging from -12db to +12db. Press enter or select on your remote and the FL speaker should come up first with it's volume. If it's closer to -12db you probably just have to turn them up as needed. My first reciever was a 2802. Good unit, clean power.
post #7 of 8
figured it out bum cable going from the reciver to the sat.
post #8 of 8
Cool, now crank it up all the way..........
