AVS › AVS Forum › Audio › Surround Music Formats › Integrity of DD using DPLIIx
post #1 of 6
When using DPLIIx to provide 7.1 with a 5.1 DD source does this mode leave the original 5.1 info totally intact? Thanks in advance.
post #2 of 6
The DPLIIx processor leaves the front 3 speakers and the subwoofer unchanged, but redistributes the 2 surround channels to 4 rear speakers, such that none of the surround speakers are playing the original signal.
Also beware that if you're working on a high-sample-rate input, such as a 96kHz track from DVD-Audio, the receiver may well downsample the complete soundtrack to 48kHz if you activate the DPLIIx processor. This will depend on the capabilities of the receiver.
post #3 of 6
Thanks dude.
How does this effect localisation if the original effect was panned hard rear left for example, would this stay the same? Does it offer smoother rear panning? I ask because i see some people just select DPLIIx for all 5.1 material and wonder if this is worthwhile for movies.
post #4 of 6
What I've noticed is that PLIIx takes the stereo image from the surround channels and outputs that to the back channels. That's a simplified version, but essentially that's what it does. So if you have a sound that is anchored in the left surround, then it will still get output to the same channel. If that sound has any stereo blend with the right surround, then PLIIx is smart enough to image it properly into the appropriate back channel(s).
Panning sounds are where PLIIx shines. It does an excellent job and really makes the surround sound more believable than with a 5.1 setup since the back channels are stereo. You can hear the direction of the pan perfectly through all of the 4 surround channels. Also, diagonal pans that move from a front channel to the surround are far more effective with PLIIx enabled. Where it gets interesting is when you take a 6.1 soundtrack and apply PLIIx with it. Since there is even more information to work with, PLIIx does an even better job with the surrounds.
Another benefit to PLIIx that hasn't been talked about in this thread is how much more spacious the soundfield is with PLIIx enabled. Surround effects like rainfall, jungle sounds, wind, ocean waves, etc. sound much more realistic since you are truly "surrounded" with 4 surround channels. I use PLIIx on every source all the time: DTS / DD 5.1, DTS-ES / DD-EX 6.1, and PCM 5.1. I'll NEVER go back to a 5.1 system again.
An artsy example of how it makes a regular movie more believable would be when I watched Turistas last night. It had jungle sounds, rainfall, and underwater scenes and PLIIx took the 5.1 surround and spread it among the back channels and really enveloped me in the effect.
post #5 of 6
Originally Posted by coldmachine View Post
Thanks dude.
Really depends on how well the current 5.1 system pans rear effects, I'd think. My 5.1 is set up close to the Dolby spec, symmetrically, with first reflections treated, and I get a continuous smooth arc between surrounds on pans, no "holes". In a system that doesn't achieve this due to placement restrictions, etc., the extra surrounds can help a lot. In my room, I found such pans somewhat less smooth with the added surrounds.
post #6 of 6
Thanks for the answers guys. I've just realised that all my questions are answered in the audio theory forum
  Back to Forum: Surround Music Formats
