AVS › AVS Forum › Display Devices › Rear Projection Units › Issue with Sony KP61 HS10. Please help!
post #1 of 5
Hey guys... I just bought an HLT6187S to replace my relegated-to-video-games seven year old KP61 HS10.
BUT, all of a sudden in 4:3 on the KP, something is all KINDS of crazy on every input. I am getting pincushion on top and bottom of over 1.5/2.0 inches. Additionally, the colors will not converge at all. The center is fine but the more toward all four corners you go the more they are separated. By a LOT, like an inch or so off. The kicker is that everything is perfect in 16:9 on input 5. As soon as I switch back to 4:3 though it freaks out again.
I was just watching a DVD on input 5 in 16:9/1080i and when I switched back to 4:3/480i and the problem was there just like that. I guess I was wondering if anyone has seen this issue before or could tell me if there is are some button acrobatics I can use to reset everything to a factory default. I have not messed around in the service menu as I am not sure how to get in there. I am out of ideas. Anyone help?
Thanks very much!
Eric
post #2 of 5
You might try re-assigning your inputs so say DVD is on input 3. I have the 61HS10 and so far my only problem is it takes awhile for it to focus. Sometimes I end up hitting flash focus two or three times.
post #3 of 5
Hey Andy,
Thanks for the reply but I am pretty sure that it has nothing to do with source material. I can have it on just noise/snow on any input with nothing plugged in and the screen is still doing the same thing.
Thanks again!
Eric
post #4 of 5
I'm not sure how many technically oriented viewers here can comment on the HS10 series but I would imagine any CRT RPTV would be subject to the problem your seeing. My guess is that the cost of repairing the problem is not going to be a good investment. The salesman I bought mine from is still around. I'll ask him if has experienced this problem.
post #5 of 5
Great, thanks very much! I figured that if anyone could help they would be here. Have a good one.
Eric
  Back to Forum: Rear Projection Units
