I am posting this on multiple boards so all of the components are represented properly. I have tried every setting, read evey manualy, done everything, but for some reason, things are not the same as they were yesterday. My wife pushed a button and all hell broke loose. Here are the questions:
I have a Onkyo 605, DirectTV H21-200, Panasonic TH-42PE7U.
1. The lip synch is way off. The audio comes out of the receiver speaker after it has appeared on the screen. How do I get them to synch up?
2. I cannot for the life of me enable the Ez Synch. The 605 should synch with the panny. They used to until yesterday. Now, I cannot change the speakers on the ez synch setting on the TV to theatre, it says to check the HDMI connection, which is fine. In other words, I cannot control volume on the 605 with my panny remote. And the bars used to come on the screen when the volume is adjusted. No longer. I have HDMI monitor out, no luck, they disappeared. I have all HDMI from the Directtv to the 605 to the panny.
3. When I turn the tv back on, the 605 comes on, but goes to DVD, not the SAT/Cable setting like it should. Again, this all used to work until yesterday. What the heck happened.
I am sure I have other questions that I forgot, but these will get me going. Please help as I have spent hours trying to fix it. Bottom line, how do I get the volume bars on my panny from the 605, how do I get the 605 and the panny to synch, and how do I adjust the lip synch issue, and how do I get the panny to recognize the home theatre speakers instead on the TV ones?
Please please please help.
