AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Onkyo 605 Owners Thread
Official Onkyo 605 Owners Thread - Page 317
post #9481 of 10231
It works perfectly with the ps3. Except it does not matrix 5.1 to 7.1 like the newer 606.
post #9482 of 10231
Originally Posted by newguy416 View Post
I may not explain this correctly but hopefully someone knows what I am trying to ask.
I am considering purchasing a PS3 to run with my 605. I have read that some receivers do not properly process the PCM very well by not applying the +10db boost correctly. Dose anyone know if the 605 processes this correctly? I don't want to loose any of the sound quality so I could get a player that bitstreams instead if this is an issue. Also if there is a setting I need to turn on or off can you please let me know?
My 605 and PS3 play very well together.
post #9483 of 10231
Thanks andydumi and chasbox. I know that with my A35 bitstreamed to my 605 sounds amazing and I hoped the pcm from the ps3 would be the same. Thanks again.
post #9484 of 10231
I searched the forum but could not find a similar post to the problem that I am experiencing.
- Onkyo TX-SR605
- Directv - HR-20
- PS3
- Optoma HD70
Both devices are connected via HDMI and have been in use for about 1.5 years with no audio problems. Output via HDMI to Optoma HD70 projector. All speakers are connected to the Onkyo.
On Onkyo HDMI input 1 (DTV), I no longer get audio on standard definition channels (live and recorded) - no issues with video. HD channels (and recordings) work fine - no issues with video or audio.
If I switch the DTV unit to the HDMI input 2 then it works fine. Swap it back to input 1 and audio problem returns.
Along the way, I tried the following:
- Swapped HDMI cables
- Powered off all devices for extended periods
- Downloaded latest software release for DTV HR-20
- Verified that Onkyo doesn't require firmware update
- None of these items had any impact.
At this point, I am assuming that Onkyo HDMI input 1 is just messed up. It seems to work fine with the PS3 - I am assuming that the PS3 is performing upconversion (if needed).
Thought maybe I am missing something obvious.... If this topic has already been addressed, I would appreciate the link to chase. Performed a bunch of searches but could not find anything similar to the situation I am describing.
Kevin
post #9485 of 10231
Last night I was unhooking a speaker cable from my 605 and forgot that the unit was on. One of the wires touched a speaker terminal and there was spark then nothing. I assume I blew a fuse as the standby light is on but the unit won't turn on. I unhooked everything and then plugged the 605 back in but it still won't turn on. When I plug it back in "Zone 2 off" flashes across the screen, but then nothing. I assume I need to take it in for servicing, but does anybody have an idea of what it is going to cost me?
post #9486 of 10231
I am having an issue that I though I had under control.
I thought that component in to componnet out was just a pass through but when I hold display down on the receiver is says 720P insted of passing 1080i.
What I have:
HD DVD > HDMI 1
Blu ray > HDMI 2
Xbox 360 > Component 1
Wii > Component 2
DVR 622 > Component 3
I have HDMI out to the TV and Component out to the TV. I thought by haveing both HDMI and Component connected to the TV the reciever would pass the native signal through. Whatever was going in HDMI would come out HDMI and the same for component. Unless I am missing something when I hold display down it shows 720p on every channel while I am watching TV with the 622.
It is really passing component untouched if it is going out component and the display information is stating what the HDMI out is?
post #9487 of 10231
What I have:
HD DVD > HDMI 1
Blu ray > HDMI 2
Wii > Component 2
i am not sure, but doesnt this unit not pass a 1080p signal for whatever devices that are connected through components?
post #9488 of 10231
I have both my sony s350 blue ray player and my HD cable box pug in to the hdmi inputs in the 605 and out to my sony kdl40v3000. The question I have is do the receiver have to be on to get picture and sound when I turn the the receiver off I get no video of sound. Is there any way to have sound and picture ouputed without having the receiver on all the time.
post #9489 of 10231
Close your blinds in your house and see if you get sunlight!
No. If everything runs thru the 605 then it must be on to get picture and sound. If you want to be able to turn off the AVR and still have pic/sound, you'll have to run separate cables from your components to the TV.
post #9490 of 10231
Hi, I bitstream DTS-HD, TrueHD, DD+, and DD from HD-DVD and BR players to my 605.
In the middle of movies, perhaps 5-6 times during the course of the movie, the 605 will produce a loud "click" just like it doesn when you switch sound tracks on the movie from DD to TrueHD for example. The display on the receiver stays consistent, displaying True HD or whatever during these clicks, and there is no interruption in the sound, but the clicks are distracting never the less. I am using a good quality HDMI cable and experience no issues other than these "clicks".
any ideas on how to troubleshoot or eliminate these would be very helpful
thanks
post #9491 of 10231
Check your 605 operating temperature. Ensure the unit is getting adequate ventilation.
My unit was originally installed in an audio rack with back panel open. I thought the ventilation would be adequate.....NOT. The unit made funny noises, then completely shutdown. I moved it to an open rack and have had no problems since.
post #9492 of 10231
Originally Posted by GarrettL View Post
I am having some serious problems/frustrations with my 8 month old 605. My problem occurs when i try to hook up my newly acquired sub up to my sub pre-out. Up to now i have never hooked up a sub to this receiver. I know for a fact that my sub is operating properly.
When I hook up the sub and run audyssey, I only faintly hear the sub during the configuration process. After it has completed, I hear nothing from my sub when watching a DVD on DD5.1. My dvd player is bitstreaming DD5.1 and my 605 is set to DD5.1 but no sub signal at all. My 5 other speakers have no problems. I called onkyo support guy and he informed me that the sub preout is supposed to output 1v when activated, and that I will more than likely have to send my receiver in for repair. I went so far as to hook up a rca cable(with exposed leads on the other end) to the sub preout in order to test the supposed 1v with a voltmeter and nada.....no signal at all.
Am I overlooking something simple, are my receiver settings wrong or am I indeed stuck with a faulty receiver? Any help would be greatly appreciated!!!
Garrett
have you figured this problem out? Does anyone have any suggestions?
I am having trouble with my sub out as well... When i plug in an older rca sub (i used it just to test), it would play fine. but immediately when I would plug in my klipsch sub (which definitely works) i barely hear anything. I have to turn the gain on the sub all the way up and the db boost on the reciever all the way up to hear ANYTHING from the sub.... then i switch the wire into the rca sub and its loud...
I don't know what to do. It cant be the sub because it was working at my friends house that day... is there something funky going on between my klipsch sub and the 605????
post #9493 of 10231
Is it a powered sub? The 605 does not power the sub pre-out
post #9494 of 10231
GarrettL and KKfromLA, a couple of thoughts:
1. How many RCA inputs are on the back of your sub? If more than one type, which are you using?
2. Many subs have a L/R pair and a single RCA labeled as "LFE". It's the LFE connection you want on the sub, since the ".1" in "5.1" is a LFE (low frequency effects) channel.
3. You are using the "preout subwoofer" (#21 in manual) and not the "subwoofer" DVD 7.1 analog input (#19 in manual), right?
4. If for some reason you did not have the sub connected and ran Audyssey, or you never had a sub connected and ran it (i.e. Garrett), then it's possible that the 605 has disabled the sub preout, which could be why you're not seeing the 1V output (just a wild guess). Have you manually checked the config before running Audyssey and see if the sub was enabled? If it's not, try enabling it first and then running Aud.
5. Also, make sure your sub input sensitivity knob is set at least half way, if not a bit more, before running Aud just to see if that helps.
6. Maybe the Aud microphone is malfunctioning and not sensing the sub?
7. From the manual p.45 "If the subwoofer (SW) appears on the SP Detect Result screen as “No,” increase the subwoofer’s volume to the half-way point, set it to its highest crossover frequency, and then try running the automatic speaker setup again. Note that if the volume is set too high and the sound distorts, it may not be detected, so use an appropriate volume level. If the subwoofer has a low-pass filter switch, set it to Off or Direct."
Hope one of these ideas helps.
post #9495 of 10231
yes it is a powered klipsch sub
post #9496 of 10231
the sub has multiple inputs, I am using a single LFE
i am using the lfe input on the sub...
yes, using the preout subwoofer
i have it all the way up just to hear anything from it... but its still barely audible on the level calibration
the sub has no switches, just a crossover, level, and phase
maybe i should adjust (raise) the sensitivity on the receiver (the subwoofer sensitivity option through the receiver's menu)
btw thanks for the help!!!
post #9497 of 10231
man another thing i noticed today is that running video through the receiver to the tv (1080i from direct tv via hdmi) actually gave me a worse picture than running components (cheap direct tv components) directly to the tv... has anyone noticed this? that picture quality goes down slightly when running through the receiver vs straight to tv... this i am not happy about...
post #9498 of 10231
I now have a 6.0 (soon to be 6.1) speaker system. I have an onkyo 605 and a ps3. I know the 605 can't matrix 5 channel lpcm from the PS3 to 6 (or 7) channels.
So what do onkyo 605 owners with 6 or 7 speaker configurations in this forum do when they are listening to a 5.1 lossless soundtrack? just listen to it through five speakers? listen to the lossy core and matrix it out to 6.1 or 7.1?
what is the optimal configuration for setting up the speakers if I am to listen to a lot of stuff in 5.1, but have 6 speakers? I know the rear should be in the middle back, but should the rear left and right be in the corners behind the listener or to the side and not behind the listener? I am talking about in an empty rectangle, nothing specific to my space.
post #9499 of 10231
I listen to stuff in 5.1 if its 5.1 and 7.1 if its 7.1.
As to placement, the 605 manual says:
*If you’re using only one surround back speaker, connect it to
the left (L) SURR BACK SPEAKERS terminals.
And place it in the center in the back.
The other 2 should be on the sides in the back.
Like this:
Where ||||||||| is the sitting area.
post #9500 of 10231
Like this:
thanks for the reply. I will put #4 and #6 in your diagram just how you show them. i did find a diagram on DTS's web site that shows it like you have it. On Dolby's web site they show only 5.1 and 7.1.
when matrixing to 6.1, is neo6 the best one to use?
post #9501 of 10231
That i dont know. I have 7.1.
post #9502 of 10231
I have a 7.1 system as well (Onkyo SP908). I listen to all TrueHD 5.1 and uncompressed 5.1 audio in 5.1. DTS-HD 7.1 in 7.1 obviously
The sound from a TrueHD track comes out of my 3 front and 2 "side" speakers with nothing coming out of the 2 "rears". It still sounds awesome.
I've been thinking about upgrading to the 606 as I believe it will matrix HD audio to all 7 speakers but not sure it is worth the price or hassle
post #9503 of 10231
Same here. I figured I will wait until the 606/607 is a great deal in a couple of years, pick one up at 100-200 bucks and be done with it.
post #9504 of 10231
Good price on the 606 here 6ave through Amazon free shipping
http://www.amazon.com/dp/B0015S8PGW/...3060_pe_vfe_t1
post #9505 of 10231
Actually my amp has a binding post input and XLR inputs....currently i am using a rca to xlr cable to connect my sub amp to the receiver.
I dont have a crossover in the sub amp...its actually a crest FA-901 pro amp driving my subwoofer. I have tested the amps inputs and they seem to work fine with other audio sources. I am letting the 605 take care of the low freq x over tasks.
correct
I didnt check to see if the sub was enabled before i ran Aud. When i did run it however the tone coming from the sub was very muffled and low. I did ensure the sub was in fact enabled at the end of the Aud process.
Didnt seem to help
Aud did detect the sub when it finished running its process....Very Very low volume and still not anywhere close to the 1v onkyo claims the preout outputs. I am measuring more like .01-.02 v from the preout with my voltometer when Batman Begins is playing on DolbyD.
post #9506 of 10231
Sounds like we have the same problem....
I sent my receiver off to have the sub preout fixed since I wasnt getting anywhere near the 1 v onkyo claims the preout outputs...just got it back from the regional onkyo support center and still have the same problems...Dosent look like they fixed a damn thing. Very frustrated to say the least!!!
post #9507 of 10231
how do you check the 1 v from the subwoofer preout?
post #9508 of 10231
I had a spare rca cable with exposed leads...hooked up the voltmeter to those leads while dvd was playing on 5.1
Going to call the Onkyo service center tomorrow to grip at them for doing nothing....wouldnt be so pissed but I had to pay for shipping to the service center!
post #9509 of 10231
Heres my current speakers and settings, just want some input:
Polk PSW110 Sub
Lower 3db 38hz
Set at 120hz in 605
Polk M20 (fronts)
Lower 3db is 55hz
Upper 3db is 20khz
Set at 80hz (605 set these up as "Full Band")
Polk RM8 Center
Lower 3db 130hz
Upper 3db 20khz
Set at 150hz
Thanks for the help.
post #9510 of 10231
I searched this massive thread but it is like finding a needle in a hay stack...
Does the 605 output HDMI and component at the same time?
