AVS › AVS Forum › Audio › Speakers › Samson Resolv 2.1 vs. M-Audio LX4
post #1 of 3
Hi I'm interested in buying a new sound system for my PC. I feel I've graduated from my Logitech Z-2200's.
With that said, I'm mainly looking at two systems: the Samson Resolv 2.1 and the M-Audio LX4. I've come across a few problems though.
The Resolv's satellites might be too big for my taste (12 inches high), but otherwise, they seem really great. The size I guess is more of a problem I have to deal with.
My other problem though, is that I have yet to find a place that sells the LX4's. They look like real solid speakers and would be a good fit for me, but from what I've seen, I'm guessing they're sort of outdated at this point. The last thing I want to do is purchase them and find that two weeks later, something ten times better comes out for the same price.
Basically, I'd like a good sounding, solid, 2.1 system that I can use for my PC for $350 or under. As a young listener, my budget is limited. If anybody would like to recommend some other systems, that would be greatly appreciated as well.
Dave.
---edit----
Just found another set of possible speakers:
Blue Sky EXO 2.1
Let me know what you think. All comments are appreciated.
post #2 of 3
*tumbleweed rolls by. . .
Anybody?
post #3 of 3
I've had the LX4 since late last year and have been very happy with them. So far they are the best 2.1 speakers I've owned. Much better sounding the my previous Klipsch 2.1 THX system. The LX4 actually has some midrange and the bass is tight and not boomy. The Blue Sky MediaDesk would have been my first choice but it was $500, way more than what I wanted to spend. The LX4 was only $200. To bad the EXO wasn't available then but that didn't stop me from pre-ordering a set It should be here next week.
  Back to Forum: Speakers
