AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Dolby Headphone progress?
post #1 of 17
Thanks for the reply, Philip. Are you saying, then, that you don't think the "DTV Audio Out" jack on my Philips would work as I understand it should work with a Sony or Sennheiser surround headphone system? That is, Dolby Headphone will not be suppying its technolgy to manufacturers for similar systems?
--John
STOP DVI/HDCP AND DFAST
What is dvi/hdcp?
What is dfast?
Visit: home recording rights
post #2 of 17
--John
Your jack will work like any jack--i.e., a 2-channel analog downconversion of the material you're listening to. Now, there are external DSP products that will reconstruct a pseudo-Pro-Logic effect from that, but Dolby Headphone has nothing to do with any of that.
Dolby Headphone must be incorporated in the player at a stage before the headphone jack. There are currently no Dolby Headphone-equipped players on the market to my knowledge.
Hope this helps,
Philip Brandes
post #3 of 17
Philip,
Wonder if you caught this thread last summer on the DH system? The Dolby rep who helped introduce it answered some questions.
The single jack on my RPTV I'm referring to is for Dolby Digital Surround. It's a SPDIF connection (Sony-Philips Digital Interface Format). It only works when the set is in the ATSC mode. So I'm not sure what you mean by "2-channel analog downconversion."
--John
What is dvi/hdcp?
What is dfast?
post #4 of 17
John,
When you mentioned the jack on your "Philips" (without identifying which Philips product you were talking about) I assumed you were talking about a Philips DVD player with a typical headphone output. In any case, the jack on your RPTV is not a headphone jack, it is designed for passing a broadcast signal in digital PCM form to a pre/pro for Pro-Logic decoding. This still has nothing to with Dolby Headphone, which only operates on a 5.1 Dolby Digital bitstream, not the Dolby Surround PCM signal output from your RPTV.
Thank you for the reference to your previous thread. I am quite familiar with the technology, having reported on it as part of SMR Forums' coverage of CES 2000 and the more recent AES Convention. As I mentioned before, Dolby Headphone is not currently being positioned or marketed for external decoder box applications. It is being implemented in DVD players, to process the digital audio signal as it is read from the disc. Whether or not it may be theoretically possible to use it in combination with other digital sources isn't clear, but it is irrelevant as there are no plans that I know of to bring that capability to market. That isn't to say that might not change, but I wouldn't hold my breath. And in any case, there will never be a way to get Dolby Headphone to work with your RPTV's digital out unless it carries a Dolby Digital bitstream.
Cheers,
Philip Brandes
[This message has been edited by Philip Brandes (edited 01-14-2001).]
post #5 of 17
If you use one of the digital outs on a dvd player, I think it would be very easy to implement an external DH decoder.
I have played around with the DH functionality in windvd and powerdvd on my computer. The produced 2 (DH decoded) channel audio was sent trough a high end audio delta 1010 sound card with external DA converters, into a class A headphone amp matched with my sennheiser electrostatic headphones.
I think the perception of the sound is very individual. I can't say that I'm impressed at all with DH!
However, I had the same experience with a Sennheiser Lucas prologic decoder a couple of years back. My friend (who bought it from me) though it was fantastic, and I could hardly hear any surround at all.
/Sören
post #6 of 17
Believe this was the 2nd WCES in which Dolby Headphone was slated to reveal new products. I see from a web search they've signed on new chip manufacturers. But I'm looking for a simple reasonably priced adapter for my Sennheiser headphones that will let me plug in the output from my HDTV (Philips 64PH9905) and hear surround sound. I'm aware of other headphone surround systems out there. Any news? Don't think I'll wait on the next WCES for firm product announcements. Thanks.
--John
What is dvi/hdcp?
What is dfast?
post #7 of 17
Dolby Headphone uses a 5.1 digital source, so it must be implemented directly in the player, and this is the implementation strategy Dolby is pursuing (especially in applications like portable DVD players and airline systems). There will never be an external "adaptor" for it.
Cheers,
Philip Brandes
post #8 of 17
You're right it can be done if you're sufficiently technically minded...my comments were about commercial products.
That's a whole other issue--whether it's worth the trouble! My own experience with DH has been decidedly mixed. I have been able to get a convincing sense of the rear channels set farther back. However, I have never heard a completely satisfying front soundstage--it's more like the usual headphone effect of sounds directly from the sides and from the center of the head. At AES, the Lake T. guys told me that it takes a little getting used to and you need to just relax and not force it. This seemed to work a little--I eventually got the fronts to extend up about 1/2 way, but never fully to the front.
Other folks claim better success with it, so I think you're right about there being a lot of individual variance.
Cheers,
Philip Brandes
post #9 of 17
Interesting. I wonder if any manufacturer includes (or plans to) some type of electronic 'positioning' adjustment so that you could tweak them a bit and move the apparent locations of virtual loudspeakers around? Thought I'd read DH was accomplished mostly with digital signal processing; you'd think such adjustments would be easy.
I'm investigating the surround-sound capabilities of my RPTV further. Philips isn't very clear about the function of the the DTV Digital Audio Out jack (RCA-type plug). Manual says it is for the connection of SPDIF audio compatible external amplifiers or home theater equipment. The RPTV has numerous external speaker connections, including subwoofer, speaker test signals, and a "Dolby Digital Surround" section in the manual says in part: "...With the new 5.1 discrete digital channel surround sound system the listener can now attain a true soundstage realism for audio signal separation, imaging, and pinpoint sound placement..."
I don't use these loudspeaker connections, but hoped to hook up the best headphone system available. By the way, Philip, I did indicate in my initial post that my Philips was an HDTV.
Edited add: Heard from technical folks at Philips. The DTV audio out jack on my RPTV is for AC3 audio when I'm in the set's ATSC (HDTV) mode.
--John
What is dvi/hdcp?
What is dfast?
[This message has been edited by John Mason (edited 01-15-2001).]
post #10 of 17
It takes a good deal of procesing to to Dolby Headphone properly, and as observed, the results will vary person to person. It works quite well for me, but then I am especially interested in spatiallity. Contrary to popular belief, Buzz does not have to do with space shots (Buzz Aldrin nor drugs) and Goddard in this case is not a Space Flight Center. It's all about spatiality, my specialty.
Seriously, I actually can get a nice front image and quite a bit of height. But it does take some learning. And relaxing does indeeed help...
Buzz Goddard
TAG Mclaren Audio
post #11 of 17
I've only heard Dolby Headphone on Singapore Airlines, and with that environment and those headphones I honestly cannot see why they bother.
Peter M
P.S. DH was developed by a small Aussie company which licensed the technology to Dolby.
post #12 of 17
Cheers,
Philip Brandes
Actually, that isn't quite right. Dolby Labs has already determined that Dolby Headphone technology is compatible with Pro Logic 2, in addition to 5.1 of course, so the possibility exists of future external adaptors finding their way to the market place or the technology being implemented in low-cost CD and 'Walkman' types of source equipment.
Charles Wood
Fosgate Audionics
Rockford Corporation
post #13 of 17
Interesting info about PLII compatibility, Charles. But the only implementations of DH so far have been for DVD playback, in the context previously discusses. is Dolby actively promoting development of products along the lines you suggest, or is this just a future possibility? Even if they're starting to plug it now, it will take some time to get it into the market. I just wouldn't expect to see products anytime soon.
Cheers,
Philip Brandes
post #14 of 17
Cheers,
Philip Brandes
I've heard the word 'possibilities' expressed as regarding the use of Dolby headphone technology in conjunction with PL2. You are correct in that it won't happen soon...certainly until full DSP solutions exist to reduce hardware/circuit board real estate and costs. Like you, I would imagine any potential products are some a year to two away from reality.
Charles Wood
Fosgate Audionics
post #15 of 17
So, I've established I do have a AC-3 (DD5.1) source: the RCA jack on the rear of my RPTV, which is active when I'm in HDTV mode (and the source is delivering).
Also, my Toshiba SD-6200 DVD player has six RCA jacks labeled 5.1 surround source. (Plus a single PCM output jack.)
Do I understand correctly there is no hardware that I can use to enjoy Dolby Headphone? Can I use a computer for a *good* system? (I have a spare 50-Mhz 486 model with Win 3.1.) Curious what has been used at all the shows to demonstrate HD--engineering prototypes? Thanks.
--John
What is dvi/hdcp?
What is dfast?
post #16 of 17
John,
The only good use of a 486 these days are as firewalls.
- I can't belive how much I paid for my old 486 http://www.avsforum.com/ubb/frown.gif
/Sören
post #17 of 17
Suspected that, Soren, for DH use. Still wondering, since the high-speed DSP chips have been available for a while, if some type of audio card didn't exist that would handle the number crunching so the microprocessor speed wouldn't be that critical. Doubted my 486 could handle the software-only DH approach.
So, there's no hardware available at all for DH...anyone?
Just checked the back of my Scientific Atlanta Explorer 2000 cable TV converter. It has one RCA plug labeled "Digital Audio Out." Wonder if it's providing a source of potential DH use, too.
--John
What is dvi/hdcp?
What is dfast?
[This message has been edited by John Mason (edited 01-17-2001).]
This thread is locked
