AVS › AVS Forum › Audio › Receivers, Amps, and Processors › D-Sonic custom Audio amps
D-Sonic custom Audio amps - Page 43
post #1261 of 1274
Originally Posted by d00m View Post
I have the M2-1500M (a pair of course) and it sounds awesome. I wouldn't worry too much. I'm pretty sure there are subtle changes between M2 and M3, maybe in the buffer stage? Just guessing. I've heard a lot of amps in all classes that I know of (A, AB, C, D, T) and to me the M2 is definitely one of the best I've heard. In it's price range it's no doubt the best.
Hello there, I am considering a new D-Sonic 5 channel amp, BUT I need some feedback first. My current amp is a 2008 rotel rmb-1095 ( 200w x 5 ) which sounds very good. My speakers are all large- PBN Montana's. Would this be an upgrade in performance? I would think so but would love to hear more from other d-sonic owners.
post #1262 of 1274
Since I haven't heard that particular Rotel I really can't give you an honest opinion. Most Rotels I've heard perform really well in their price range. I wild guess though would be that the D-Sonic amps would be an improvement, based on my experience with various amps. smile.gif
post #1263 of 1274
Hello All,
The M2-1500M and M3-1500M are identical.
I originally went to the M2 designation to reflect new cosmetics, grounding and EMI/RFI shielding. The 6 Moons review was done at that time. After the review was published, I decided to change all of the newer technology amplifiers to the M3 designation to make a clean separation between the M2 and M3 series.
Dennis
D-Sonic Custom Audio
www.d-sonic.net
800-862-7998
post #1264 of 1274
What is the sensitivity of the speakers and the recommended amount of max power (WPC)?
Chris
post #1265 of 1274
All amps sound the same anyway ;)
(sarcasm) btw
post #1266 of 1274
Chris
Hi Chris, the speakers are easy to drive... -92.5db sensitivity. The recommended power is 150 - 500 watts per speaker. ( But I'm sure the Montana's could handle a lot more if needed;)
thx for your reply,
Bri
post #1267 of 1274
I actually agree with you for the most part. As long as the speaker being driven has enough power to drive it effortlessly without running out of headroom there should be no audible differences, unless the design purposely intended to put there own sonic signature on the sound being amplified or the amp in question is broken.
It is when the amp starts clipping that breakup can occur. This breakup causes distortion which can lead to a perceived audible different sound.
Chris
post #1268 of 1274
thx for your reply,
Bri
In this case 500wpc will drive your speakers better with less effort then 200 wpc the higher you turn the volume up and the more dynamic the source material being reproduced. You should notice that the speakers become more effortless.(faster tighter and more punchy) but the sound will not change. An amp should accept the signal, amplify that signal, and send it back out neutral with no color.
This amp should be more efficient then the rotel and not get as hot. Those are big pluses IMO. I've had/have a lot of amps this is by far my favorite total package amp. I have the M2 1500 it weighs less then 30 pounds yet puts out 500 wpc and never heats up. That is Awesome! smile.gif
Chris
post #1269 of 1274
Good Stuff Chris! I think I am pretty dead set on getting the 5 channel M3 from Dennis. His prices are real good.......the Wyred 4 Sound Amps are VERY similar in design and performance, but more costly.
enjoy!
post #1270 of 1274
enjoy!
You won't be disappointed.
post #1271 of 1274
Chris
Not quite all of the best questions. The best questions are:
(1) Efficiency of speakers?
(2) Speaker positioning whether along wall or in the middle of the room
(3) Preferences for SPL - if you don't know, get a SPL meter right now - they only cost $20-50.
(4) Listening distance
(5) Subwoofer yes or no, and the only reasonable answer is yes.
post #1272 of 1274
Chris
I used to think this too. Actually when you are merely loud and using 5watts or less your speakers won't see or taste or smell the difference in potentially available power. The physical laws of the universe require that at any given voltage into any given speaker the current and therefore power have to be exactly the same. It's not a law like the speed limit it's like gravity. Always there and unavoidable. Increase the voltage (also called turning up the volume) makes things louder. At any spl that is within the audibly clean and linear band of an amp voltage and current have to be the same so power has to be the same regardless of remaining headroom in amp power.
Aside from intentional treble roll offs the most likely amp spec to make a sonic difference, assuming you are not distorting the amp, is output impedance. High enough output impedance into a difficult enough load can cause the amp to have frequency response peaks and dips that could be audible.
post #1273 of 1274
Those laws do not require that all amps be able to deliver the current demanded by that voltage, in which case the voltage will of course drop.
Which is not to make any statement as to how likely this scenario is.
post #1274 of 1274
Its called clipping. Basic premise remains. Didn't I say linear? Clipping isn't linear. If the less powerful amp clips audibly the 2 amps will sound different. Experience suggets that at lower distortion levels the clipping amp will sound better to many. Virtually guaranteed it will be perceived as louder. Distortion sounds loud. Also clipping implies some dynamic compression, raising average levels and sounding louder.
