AVS › AVS Forum › Audio › Receivers, Amps, and Processors › AMP Connection
AMP Connection
post #1 of 6
I'll be connecting my Denon 5700 to a EAD 1000 in a few day, what's the best way to connect them?
Joe
[This message has been edited by jfrano (edited 01-16-2001).]
post #2 of 6
with wire. seems to work better than cotton balls or peanut butter...
http://www.avsforum.com/ubb/smile.gif
dave
Widescreen DVD - Because a superior format requires superior formatting.
post #3 of 6
The only thing I can say...."that's so funny...I forgot to laugh."
post #4 of 6
Is this only done with RCA type cables or are digital connections possible?
post #5 of 6
Assuming you are talking about EAD's PM1000 amp, then yes, you would be connecting your Denon 5700 to the PM1000 via RCA audio interconnects...
post #6 of 6
Great, thanks.
I will be running about 6ft. What is the general consensus about the needed quality for cables such as these?
This thread is locked
