Here is the final test of the EP1500. I have tested both 8 & 4 ohms bridged mono. The 8 ohm test went well but the 4 ohm test did not fare too well even at 1 KHz so I did not even go any further with it. The circuit breaker on the amp kept blowing just as I would aproach ful power in 4 ohm bridge mono. Note the increased distortion at 4 ohms also.
Ok, that is it for the first amplifier in my tests. If you have comments, gripes, suggestions, or preferences for a format let me know now or forever hold your peace (yeah, right, on AVS
). I am going to try and fashion some tests to fit with Binks spreadsheet but that may be down the road.
Chuck
