AVS › AVS Forum › Audio › DIY Speakers and Subs › Measuring Amplifiers
Measuring Amplifiers - Page 26
post #751 of 1913
With their powerful, reliable performance,
XTi-Series amps easily handle 2-ohm loads
and are capable of chest-thumping lows.
Subharmonic Synthesizer: Takes the lowfrequency
content of the input signal and
“synthesizes” a new signal that is the same
as the input signal but one octave lower. The
new synthesized signal is then mixed with the
original signal to create the effect.
Chest thumping is centered around 70hz, therefore no lies there
Subharmonic Synth?
http://www.crownaudio.com/pdf/amps/139472.pdf
post #752 of 1913
BTW, just hit me, the DSP is off? It looks like its a 4dB HPF, or a -4dB PEQ low Q.
post #753 of 1913
Penn,
Since you quoted what I had stated, I will say it again with the same conviction. Going from the Buttkicker to the XTi was a vast improvement to me. Just because it (the XTi) seems to be weaker than advertised does not negate the difference I hear between those amps.
Also, just because of these tests does not mean I want to all of a sudden throw it away. I would just like to hear what Crown says about it if anything. I am happy with it and it will stay in my system. If you want to come on up to Boston and help me change them in and out you can tell me if you hear a difference between them in my setup
Exojam, Im actually with you!! I have several of the amps here that have been HAMMERED by the tests and I still use them knowing that I love the sound STILL. Although Im still thinking there is something more to the Xti test...no way it only has that many Watts at 20Hz...
Anyways, I did pick up a second SC-1250 and I will have that tested if it works out well then I might replace all my amps with the Velodyne SC-1250...RCA connects, no fan, nice home audio rich look (not the normal PRO amp ugly stuff), REMOTE CONTROL!!!
Bizarre how the amp drops in output from 50Hz to 20Hz.
On an semi-related note, has anyone seen these amps?
http://www.audiolines.com/Samson-PG2...p-p-21076.html
http://www.audiolines.com/Samson-PG3...p-p-21077.html
They look like they could be good values...
I hate you dammit, I just hate you...I like the 1000W per side @ 2 ohms for $200!!! Heck that is cheap enough to just buy and send to Chuck....Chuck I hope you are not to busy
Here is another amp I found today....Marathon MA-5050 1900 Watts Per Channel 4 Ohm DJ Amplifier for $750 (- Output Power 2 (ohms): 2 x 2500W, Output Power BRIDGE 8 (ohms): 3600W, Output Power BRIDGE 4 (ohms): 5000W )
lots of amps out there too buy and test
post #754 of 1913
Chuck,
mabey HiQnet System Architect 1.7 will give you easier control of the XTi over usb
http://hiqnet.harmanpro.com/sa_download.php
post #755 of 1913
Thy,
I don't see how the sound between those frequencies (35hz - 100hz) would be inaudible between the Buttkicker and the XTi. The Buttkicker measured 14% distortion at 50 HZ. All I did to hear the difference in music was to play something I listen to on a regular basis, cranked it up and sat right next to the sub and could tell the difference.
post #756 of 1913
Crown ...you better answer.
I am not going to give this 90W monkey business a rest until this is either solved or I return my amps and exchange them for something else.
Tomorrow I will run test tones,at very high SPL. Lets see how TC-3000 react.Lets see what Clown Inc has in the tank.
post #757 of 1913
Please do.
post #758 of 1913
Looks like more QSC PLX II for TheEAR....
post #759 of 1913
Looks like Clown will have alot of clowning to do to come out of this.
I never knew I had three Clowns R Us amps !
Its a powerful performer for HEADPHONES ! I could not even damage in ear drivers with this much output at 20hz.
post #760 of 1913
You could always build a tweeter array......
post #761 of 1913
I am going to do better...an altar of Shame and Clown will be the guest of dishonor.
post #762 of 1913
lets wait and see if there are any filters still set or if something else is wrong.
post #763 of 1913
Please do.
lol, I already have it in a shopping cart.. I can not resist a $200 amp with specs on paper like this.
EDIT: I decided to buy the Samson PG3800 because its only $360 shipped and if it only does half of what it says it will drive my IB array very well. (The PG3800 offers up to 3800 watts of power bridged mono at 4 ohms and 1800 watts per side at 2 ohms.) The PLX3402, XS1200 and XTI4000 are the other amps with those posted specs.....For $360, I doubt it comes close to those, except now the XTi one is probably questionable.
post #764 of 1913
I corrected my post to read "20 msec". My bad.
post #765 of 1913
That may be a point to check out. The amp front panel and DSP can be locked using the HiQnet system and (that) cannot be released with the front panel display.
Chuck, did fireanimal have any presets in the DSP? If he did was there a Frequency response curve installed looking like the result we're trying to analyze on your test result?
And the last excuse . . . . . if UPS DID drop the amp and/or bounced it hard enough to dislodge the fuse from it's holder could there be some damage to the unit?
In any case I think the amp should be sent to crown for analysis.
post #766 of 1913
Most excellent!
I'd say even if it can do 75% of those numbers on Chuck's test, its a darn good buy. You'll have to start a thread on it, post the full manuf. specs (can't find them anywhere), and tell us about the fans, etc.
post #767 of 1913
Originally Posted by exojam View Post
Thy,
I don’t see how the sound between those frequencies (35hz - 100hz) would be inaudible between the Buttkicker and the XTi. The Buttkicker measured 14% distortion at 50 HZ. All I did to hear the difference in music was to play something I listen to on a regular basis, cranked it up and sat right next to the sub and could tell the difference.
I'm referring to only the XTI, < 35hz vs. > 35hz playback. I don't know
what your system is or music.
post #768 of 1913
Tapco Juice J-2500 is on sale for $299 shipped at MF.
post #769 of 1913
"All readings were taken with a THD set between 0.475% and 0.5%. "
That could be it right there.
Maybe the Crown will produce its rated power at 20 Hz, but with much higher THD, in which case it would be easy to believe it could go unnoticed.
So the question is, at what power does it actually hit the voltage rails?
post #770 of 1913
The reason that I don't think that there are any filters set is the distortion on the measurement. Chuck took the measurements all at close to .5% THD. If the DSP was on with a filter of some sort you wouldn't really expect the distortion to jump as a result, would you? Even with a filter set, it should still get pretty much the same power output in this test. This was a test up to a distortion limit, not the front panel gain limit.
post #771 of 1913
If it were a filter issue we would see a drop off in the 8 ohm measurements as well, in which we don't. I highly doubt there is a 4 omm only filter.
post #772 of 1913
I guess I will ship my Velodyne sc-1250 amp to Chuck and see what the true numbers are there too!
did this happen?
though i already bought a Behringer EP2500, i'm curious about this amp.
can someone do a running graph of these tests?
yes i'm pushy.
super thanks chasw for doing all the hard work.
post #773 of 1913
Thy,
Sorry, I misunderstood what you were referring to.
post #774 of 1913
When I initially received the amplifier, the first order of business was to clear any and all DSP settings so that they would not interfere with measurements.
Chuck
post #775 of 1913
When I received the amp the only setting used in the DSP was to set it in 'bridge mode'. I read the manual and used the manual to go through all settings and zero them out, After having done that, the front panel display would always read 'NO DSP' and none of the icons would be illuminated.
I just find it real hard to believe that the amp would drop so quickly at a particular frequency, but in addition to the spreadsheet I published I spent many hours just taking readings and checking settings looking for reasons that might affect the amplifier. I would much rather find out that I am a dumb ass for missing a setting than to condemn the amplifier. If the amp were mine, I would take it to a Crown authorized service center and point out the wattage readings and ask them to see if they can reproduce it and whether or not it falls under warranty repair. They might say it meets published specs and sorry, or they may say it is a problem and repair it. It could also be a glitch in the microprocessor control built into the amplifier.
Chuck
post #776 of 1913
So, no DSP, everything cleared. Got that out of the way...
I'm so stupid, if there really was a DSP filter then it would have affected 8 ohms 20Hz too anyway. Well at least 8 ohms is running 20Hz a-ok, so 8-ohms drivers are ok as long as the impedance dips do not get too low.
If something is indeed faulty in the amp, is it probable that both channels are affected simultaneously? And to the same degree both channels, as far as power is concerned? I'm not an expert, but my guess is no.
Just 2 weeks ago I nearly wanted to get this amp too as the DSP is good and convenient. But something pulled me back when another forumer told me there is "NO CONTEST" (his exact words) when he compared between the XTi2000 vs Face Audio F-1200TS (old school design). He tried everything from DTS-20 to growler, 1 per channel, 2 per channel, bridged, high level volume and even low level volume. Not as tight...No Contest, yada yada. He thought that the Face Audio was a mistake and wanted to change to the XTi so was trialing it. Together with some pro users who used it for sub duty saying that they did not like the low freqs (together with the Yamaha flagship P7000S). That did it for me....
Who has an I-tech?
post #777 of 1913
Very good observation and also what I suspect.
Maybe with 2-3% THD it can get closer to spec,not meet spec(as it does not meet at 1KHz either).
The can O worms is open,Crown better step in and explain this poor performance.
I will calm down and run some heavy test tones on TC-3000 sealed 15's ,it will not go very far with 90W if true.
post #778 of 1913
did this happen?
yes i'm pushy.
Hasnt happened yet, I have two SC-1250s and they are being used for my own in room measurement tests once Im done with that, I will send one off too Chuck.
Im hoping to ship it Monday or Tuesday.
post #779 of 1913
Couldnt we say this about the Dayton 1000W test too? I didnt see anything about the set THD but we could use higher THDs to get closer to the specs?
post #780 of 1913
If you read the 20 Hz distortion level at 8 ohms, you will see that it is above 2.X% THD to achieve its power. This is why I took the path of using stated THD figures on the 4 ohm and 2 ohm measurements.
Chuck
