AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › What I'd do differently next time.
What I'd do differently next time. - Page 22
post #631 of 791
While not entirely discounting the whole 'make noise while the baby is young' theory entirely, I think you might be over estimating the whole whole cause & effect of that. I noticed that despite similar noise exposure in infancy, each of our kids seemed to have different noise tolerance as they grew older, and that if anything it seemed to vary according to their age more than anything - even those who woke early or easily as toddlers seemed to sleep through anything and everything as teens or young adults. Go figure.
In any case, soundproofing a HT while doing the construction at least gives you the option of containing or minimizing the noise down the road if you want to ... and my money would be on the likelihood that there will be plenty of times when you - or your wife - will want to do that. Conversely, if you don't do it now and decide later that you want it, it will cost a lot more to retrofit it.
FWIW, I read somewhere here that one of the HT gurus - perhaps it was Dennis Erskine? - listed the top reasons why people stop using their HT regularly, and one of the top 3 reasons was the lack of sound containment.
As for your other question, sound proofing/containment is NOT a substitute for acoustic treatments within a room. Two different issues.
post #632 of 791
If your audio components are high quality, they should be capable of producing quality sound in a smaller room as well as large. You just don't turn them up as loud.. :P
There are two ideas that are typically used for the projector mounting (other than getting it at the right height.. in your case, as high as possible, which should be about 3-4" from the ceiling). The best method is a long throw projector that goes in a room behind the theater and projects through a hole. It's quieter, easier to direct cooling to it, and keeps it out of sight and out of the way. If it must be in the room, mount it directly above a row of seating, since you'll never be standing on the seat.
Soundproofing the walls helps with the room acoustics by providing mass and minimizing possible rattling/vibration, but it's really more about isolating noise for the theater (keeping other noises out and keeping the audio from escaping). It's definitely not a substitute for good acoustic treatments. A well soundproofed drywall box is still going to sound like an echo (not anechoic ) chamber.
post #633 of 791
Great, I really appreciate the input. I will definitely include plans for acoustic treatments and/or curtains for the budget planning.
post #634 of 791
Originally Posted by miltimj View Post
That reminds me. Whatever you do Sideofpotatos, make as MUCH noise as possible in their first couple months or so of life at home. You'll be glad you did. I remodeled our basement right under my daughter's room (just plywood between us) from the time she was 2 days old, and used all of the following right under her at various times prior to or during her sleeping: miter saw, framing nailer, table saw, grinder, recip saw, circular saw, framing hammer, sledge hammer, 22 caliber concrete nails, hammer drill through concrete.... I am absolutely dead serious. I had my hearing protection on, and she slept through the whole thing. She's now 26 months and has been able to sleep through anything.
Our second daughter.. not so much. Goes along with "what I would have done differently"... I was too busy taking care of the older daughter and doing some other things (not remodeling), and she's a lighter sleeper. I'm slowly ramping up the noise, though.
I have to agree as well. My daughter had to spend the first week of her life in the Newborn ICU. It was never quiet in there since all the machines the babies were hooked up to kept beeping loud constantly. Throw in workers, parents, and the phones, and you have a pretty loud room. Anyways, for the first 6 months of her life i was afraid she was partly deaf because loud noises, really loud, would not wake her up. She slept through a noisy dave and busters meal, she has slept through a movie at home with loud bangs, pretty much anything.
post #635 of 791
Hi to everyone, just embarked on dedicated HT in basement, working in a bar also,
enjoy your commentary and insightful replies Im just finishing up prewire, insulation,
support nailers etc. Next step is drywall, somewhat apprehensive to take this step
as thinking about all the what-ifs, why didnt-I's etc.
chat soon.
cheers
post #636 of 791
@cavedirt, Start a build thread so we can follow and give advice. Just curious, do you work in a bar, or are you working a bar into your build... ?
post #637 of 791
oops......meant building a bar as well as theatre...will round up all necessary info..
thanks bh285
post #638 of 791
Cool. I'll keep an eye open for your build thread. Lots of pictures helps!
I'm working on my build as well, but have not started a thread myself.
post #639 of 791
This is an awesome post guys, thanks for the advice!
Ill definitely get a 2" conduit going from my main level downstairs for cabling as well as one going from the media rack to the back wall in the basement - before I close off the space with drywall! Also it looks like HDMI covers are the way to go VS plugging the cables directly into my devices.
post #640 of 791
...Not make decisions on an empty stomach. Those decisions will be in the best interest of said empty stomach.
John
post #641 of 791
1) Like others have stated, room gets pretty warm with large parties & projector running: some sort of hvac add on (another complete zone/system -- very expensive from what I understand)
2) Place room under kid's rooms instead of mine -- even though the room is very soundproof, when system is cranked, wife complains when she's directly above it and hears the bass (even though it's not THAT loud upstairs -- a tv at regular volume drowns it out -- not that I'm bitter or anything
3) Use backing behind screen -- on certain movies with black background & white text (think Star Wars beginning scenes), I can see the text being lit through the screen (should I spray paint the OC 703 behind the wall black???)
post #642 of 791
Just cover with some cheap FR black fabric.
post #643 of 791
Different Next Time:
Build a false wall and utilize an AT screen like everyone told me too. (And I'll just pretend the wife gave me permission).
post #644 of 791
Yes. AT's are great for so many reasons and as projectors get brighter they become more practical. I went the AT route and am very pleased.
post #645 of 791
Originally Posted by Dennis Erskine View Post
5. Screens
---- Screen too big for the room. Screen widths should never be more than 80% of the room width. Keep the screen at least 3' off the floor (if not more) and don't mount it within inches of the ceiling. Big is not always better.
Isn't 3' somewhat subjective? Does it not depend on viewing distance? If you are 15' away from screen, you might be able to get away with 2' off the floor. (I know, you'd need a huge screen and a light cannon, but let's assume you can get that)
post #646 of 791
Among other things 2' off the floor means you better have an AT screen and at least the center speaker behind it. A speaker at two feet off the floor is typically compromised. And there better be room aside the screen for the left/right, or an AT screen with them behind, or... again, a compromise on sound.
But perhaps more important -- since one assumes one has an extra large screen because image is what matters -- if you like to recline when watching a movie, you'll possibly have trouble comfortably seeing the bottom of the screen when it's that low...
post #647 of 791
Yes .... 3' can be somewhat subjective; but, OTOH, it is also not incorrect considering the eyes are generally 42" AFF when seated. Viewing angle is the criteria. That will generally place the center of the screen at about 10 - 12 degrees above eye level for the first row. You have more than two rows? ... then things change a bit.
post #648 of 791
My screen is huge by most standards. 168" wide 2.35 in a 208" wide room. I was about to put a comment in that Dennis's recommendation of not exeeding 80% of the room width could be stretched. Then I did the math. I'm right at 80%.
post #649 of 791
Thanks. I think that it also depends on viewing distance. Your 10-12 degree criterion is appropriate and I think that one should stick with that. As you sit further back, the screen can drop a bit while still being in that viewing angle range.
post #650 of 791
I am planning a nearly identical screen. Which screen and projector do you use? What's the screen height from the floor and your viewing distance? Thanks
post #651 of 791
DIY, I don't want to take this thread off topic, so please PM me or visit my construction thread if you have any other questions. I'd be happy to talk.
Briefly, I have an AE4000 with the SeymourXD material. 20" off the floor and seating distances of 12', 19' (primary seating) and 24' (bar).
post #652 of 791
What I would do differently...I had roughly a 15.0' wide area for my HT. I made a built-in for this area. I was short sighted on additional cabling that I had not considered (LAN cable, front height speaker cable, etc.). I either should have added this in the first place or made a cable tunnel in the bottom of the built-in cabinets with access to more easily and cleanly run these additional cables. It took a lot of "Fishing" and frustration to add these after the fact and took a lot of work to hide the cables.
post #653 of 791
I have heard the eyes should be 1/3 up the screen. That would give similar results to yours at certain viewing distances. I'm too lazy to do the math. In any case, that puts my 10' wide 16:9 screen 2' up off the floor. While it works well with my seating and a 15" riser for the second row, I am considering raising it to make the front row better suited to tall people. The 3' height may be a good compromise for me.
post #654 of 791
I prefer eye level to the center of the screen if possible. That presents the most "correct" and believable image geometry to the eye. All the perspective cues are captured directly on by the camera. The more off-axis you place yourself, vertically or horizontally, the more you introduce tell-tale shifts in perspective that tell your mind "I'm looking at a flat image."
I had a pretty complicated system for trying to achieve that (since my image size varies, as does my image center to some degree). But I got pretty close.
Occasionally someone comes in the room and says "wow, your screen is pretty low" since many people are used to looking up at a screen to some degree. But once they sit down the angle suddenly makes sense and they go "Oh...now I get it, this feels perfect!"
post #655 of 791
Make sure my outlets on the front wall are level with each other. Pay someone to do the drywall.
post #656 of 791
Originally Posted by stepyourgameup View Post
pay someone to do the drywall.
+1
post #657 of 791
Originally Posted by nathan_h View Post
+1
I just can't justify paying someone $800 to do the drywall.
post #658 of 791
Unless your good at it yourself then it is money WELL spent and the professional results in such a little time frame cant be beat.
post #659 of 791
Very true, however, when the lights go down nobody will see the drywall. I would rather put the money into a new projector or an Epik Empire.
post #660 of 791
You can if you've ever done it yourself. If you haven't done it yourself I'd get someone to mud it for you at least. But that's just me.
