AVS › AVS Forum › Audio › Receivers, Amps, and Processors › My old AC-3 receiver won't decode new DVD players--WHY?
post #1 of 9
I have an old Pioneer Elite Receiver with AC-3 that decodes a similar generation Pioneer Elite DVD-Laserdisc combination player fine. The DVD's can be heard in AC-3/Dolby Digital 5.1 with no problem. I use a single RCA patch cord to connect the digital bitstream. However, when I try to hook up a recent DVD player the same way, the receiver just won't decode it. Has the standard changed since the old equipment came out? Did it go from 16 bit to 24 bit or something while I wasn't looking. Can someone solve my mystery?
Joe House
Still think the 1300 lumen Infocus LP350/Boxlight CD555m DLP, with its video decoder, de-interlacer and scaler is a steal.
post #2 of 9
I need some help here!
Joe House
post #3 of 9
Have you gone into the DVD players' menu and set it to output Dolby Digital? I don't know why, but even newer players have the default set at Dolby Pro Logic at the analog outputs. Other than that I can't imagine why it wouldn't work....whether it is a new or old player shouldn't matter. Maybe the DVD player is broken?
post #4 of 9
Hi JHouse,
I think it is that you because you had a Pioneer combo player and receiver it masked the problem that your receiver only process signals from a LD player. I am sorry that I do not know the specifications but this had happen to me too.
When I first got my Sony DE915 DD reciever it had an AC-3 coax input. I got myself a new RCA DVD player with digital coax output. I hooked it up and then...... nothing happen. The AC-3 coax input was for digital streams from a laser disc player not DVD player. I got a different DVD player and it would still not work.. Later I got a preamp and the DVD player works fine.
I think that there may have been a "conversion" circuitry so the output AC-3 output from the DVD/LD player could be recognize by the receiver.
clopez
post #5 of 9
Joe,
I'm unfamiliar with your older Pioneer combo DVD/LD player, but most AC3 laserdisc players emitted a 12.288mhz QPSK AC3 RF (output directly from the space taken up by the old right analog channel on the laserdisc) which would be fed to an RF-Demodulator. The RF demodulator would then convert the QPSK RF signal to SPDIF. Most older receivers/processors had both an AC3 RF and coaxial SPDIF input. Your receiver probably says AC3 RF input. DVD players never used RF for their digital audio outputs, DVD players provide a co-axial/optical SPDIF output only.
The SONY dvd player that I have has a submenu option for enabling digital audio out.
Check the connection on your receiver for "AC3 RF", if RF is not called out than it is probably SPDIF. If this is the case ensure your DVD players digital output is enabled.
My laserdisc player's AC3 RF output ispatched thru an outboard RF demodulator prior to being passed into the co-axial SPDIF input in my processor.
Hope this helps.
John
post #6 of 9
Thanks guys. I guess it's time to trash 145 watts x 5 channels with rosewood side panels and graphic user interface that cost $2200, and replace it with a $500 Denon. Reality is evil.
Joe House
post #7 of 9
Joe,
One other item to check on your new DVD player is that the output should be set to 16 bit if possible. Your older Pioneer receiver if it did accept an SPDIF input will be looking for 16 bit at 48Khz sampling rate.
John
post #8 of 9
Is this the VSX-99? My brother runs his DVD in via the coaxe DD input for Satelite. At the time they thought that would be the next DD source.......
Rachael,la gata del disco Grande
post #9 of 9
The midiman co2 will fix your problem. It changes optical to pcm or rf.
I am using one for my vsx 99.
Steve P
This thread is locked
