Anyone have a VIZIO L37 with the following problem:
1. While watching TV the screen went blank and a high pitch load buzzing sound
started. I shut the TV off, waited than turned back on.
2. The picture now has gotten much smaller, no sound and a green back ground.
3. Went to the input mode tryed different settings. TV mode had a pink back
ground no sound. DVD mode had a green back ground.
4. Went back to Digatal HD mode, picture was normal but had green background
that bleed through the normal color.
5. Went back to the Adjustment mode and switched the sound to DVI...it than
worked.
6. So this is how it is ...all channels work...color is normal but the background
green bleeds through so you have everything tinted a slight green. And the
sound works only on DVI.
Please reply if you had this problem
Thanks for your help
worked.
