Originally Posted by lionzden
i have since placed a good heatsink on my Panasonic DMR-EV475V i got new for $42.00 cash on craiglist, however' just one more thing and that is the fan does not spin' so i modded from the stock 7v fan to a 12v sunnon 80mm out side the case with epoxy and a wall adapter to molex, work really good, i cut out the factory grill and put a chrome finger guard on my sunnon for better air flow and it even looks good, so there may aswell be a problem either with the stock 7v fan or the onboard fan connecter so i just bypassed them both, arctic ceramic adhesive works great to mount the heatsink aswell, thanks again
It's good to read of modifications that allow EZ series machines to function better than those that many of us must endure.
I own one 2008 DMR-EZ28 model and four 2007 DMR-EZ17 models. All are in current daily use. The 2007 models are more prone to be problematic than the 2008 model. The 2007 models have the occasional scheduled recording pause/record/freeze-up with counter at 00:00:00. These and other freeze-ups, requiring use of the reset button to regain control, are common to the 2007 and 2008 models.
One difference between the 2007 and 2008 models is the Digital PCB and the chips found on that board. The first photo shows a 2007 EZ17 Digital PCB that has LSI and ATI chips. The second photo shows a 2008 EZ28 Digital PCB that has Magnum and AMD chips.
Panasonic did not use heat sinks on the large chips in 2007 and 2008. There were heat sinks fitted to the largest chip on the Digital PCB in the 2006 models. The third photo shows two Digital PCBs found on DMR-ES35V models from 2006. The fourth photo shows the large Panasonic brand chip on a DMR-ES35V Digital PCB. The fifth photo shows the RAM and some other chips on the underside of a DMR-ES35V Digital PCB.
The Panasonic Service and Technology Company (parts) website is down at the moment so I am unable to locate the retail price of a replacement RFKB79142DP Digital PCB used on the DMR-EZ47V/475V.
Addendum: This morning the PSTC website is functional. The RFKB79142DP DIGITAL PC BOARD for a DMR-EZ47V/475V is priced at $150.28.
