Hey folks,
I have a question which I'm sure someone here probably has the answer to. But first, my setup.
I subscribe to XM satellite radio. At home, I have a Polk Audio reference receiver in the living room and a Delphi RoadyXT (in a boom box). I also have XM in my car.
I subscribe to DirecTV (w/ HD) and have three H20 receivers.
My XM reception at home could be better, so I decided to so some research into indoor/outdoor mounted antenna. I have all but settled on the Pixel Logic PRO500 amplified antenna, a splitter, inline amps etc.
At the same time, since I just built a new HTPC for recording my shows (I didn't want the displeasure of using an HR20, since DirecTV's idea of DVR software has a long way to go).
I want to connect both the DirecTV antenna and an OTA (I have settled on the Winegard GS2200 Sensor III) to my HTPC (which has dual Hauppage 1600 tuners in it).
So......
Since my house is already wired for DirecTV (standard RG6 cable), I was looking around for a DBS combiner/splitter kit which would allow me to connect both the DirecTV and Winegard antenna on the same RG6 cable run. Not only will this be cleaner, it will also be cheaper.
Sirus has a DBS combiner/splitter kit which does just that, but I can't seem to find a comparable one for XM.
So, does anyone know (a) if its possible to do what I want above (b) if so, is there a comparable XM combiner kit (Google was no help. Seriously)? If not, is there a way to actually do with off-the-shelf parts (e.g. from RadioShack or similar?)
Thanks!!
So......
Thanks!!
