AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Blu-ray disc rot on a few titles!
Blu-ray disc rot on a few titles! - Page 6
post #151 of 397
Originally Posted by dbburns View Post
Uh oh. I will try to remember to check mine when I get home. I've watched it twice, once at release and then again about a month ago, no problems.
The only time I saw this type of 'rot' was after I had a house fire and water and moisture from the water caused this in some of my DVD's. Maybe you guys have a lot of moisture around?
post #152 of 397
Originally Posted by michael000 View Post
These are all the numbers on the discs inner ring i'd imagine the first one is what you're looking, but i'm not sure so i just jotted them all down.
IFPI L322
BVDL-006620A1
BVDL-006620B1
9
7
A04
A06
BVDL-005620B1
BVDL-006620A1
7
A03
IEP1 L322
9
Guess mine is the same.
Just checked ~ 20 BR movies, 4 ps3 games. None show the rot.
post #153 of 397
Im a little uninformed on disk rot. When some of you posters talk about DVD disk rot, did it happen right away? Will all DVDs eventually rot; by that i mean, is this a problem with disk it self, or how they were stored, treated etc? I was under the assumption that DVDs that are pressed will last a lifetime, vs burned DVDs. I hope none of my old collection has rotted, id idnt even know it was possible.
I hope all your guys BD get replaced promptly.
post #154 of 397
Originally Posted by AaronSCH View Post
I guess there is another benefit to living in a dry desert climate. I never saw anything like this on a DVD, HD DVD or Blu-ray disc. That's pretty bizarre.
Me either. Hopefully i don't get any of those in the future.
post #155 of 397
Originally Posted by Paul Arnette View Post
The numbers on the inner ring of the disc, are those only for The Prestige? Does anyone have the numbers for The Departed and Stranger Than Fiction if they are?
I posted mine for Stranger Than Fiction a few posts above. My Departed is fine.
Here is STF:
Inner rim:
BVDL-006180A1 4
BVDL-006180B1 1
Steve
PS: DVDPacific won't replace mine Unsure if I'll buy another.
Also I think I'll go for HD-DVD in the future of the same title.
post #156 of 397
Seems like it's a bad production run of 50gb disks. Only the "BVDL" has been affected. The single layer disks are coded BVSL or something similar.
post #157 of 397
Here is STF:
Inner rim:
BVDL-006180A1 4
BVDL-006180B1 1
I'm pretty sure that's the catalog number of the release, not specific pressing info.
I just bought a brand-new STF from Amazon, and it had those same BVDL numbers (and no rot).
post #158 of 397
I live in Sunnyvale, CA and own all three - Stranger than Fiction, The Departed, and the Prestige. All three purchased on day of release. Discs still look perfect.
Marty.
post #159 of 397
Here is STF:
Inner rim:
BVDL-006180A1 4
BVDL-006180B1 1
Steve
go to sony (or whomever published that title) and tell them about this, i think they will get you new one so they can get the one you have to take a look at it and figure out why there are issues.
post #160 of 397
Uh-oh. Sony laserdiscs were notorious for being susceptible to the dreaded rot. Gonna have to check my Blu-rays tomorrow......
post #161 of 397
Sony is keeping ya coming back for more.
post #162 of 397
Checked over my 30 or so BDs and no rot.
post #163 of 397
My Prestige has very minor rot. I had to look really hard for it in really bright light.
My Departed looked fine, as did The Descent. I didn't bother to check any others.
post #164 of 397
I checked my Prestige and saw no signs of rot.
post #165 of 397
Originally Posted by HumanMedia View Post
...Hopefully Aaron will STFU now.
Nah... I never liked to be told what to do. Especially when I was right.
post #166 of 397
Originally Posted by egcarter View Post
Do you guys with the spots live in humid climates?
This is my thought too.
Does anyone with the rot problem have a home without an air conditioner or store their movies in a home theater that's in the basement (perhaps without a dehumidifier or needs to add another)?
If you have the rot, then post something quick about how and where your discs are stored.
It'd be nice to center on why this rot is occurring. If it's only happening to some, then hopefully the problem isn't a factory defect which could eventually effect everyone and all BD discs.
post #167 of 397
This is an isolated phenomenon that inevitably happens when a new technology is introduced. It has happened on a limited basis with some CDs, LDs and DVDs. There is no reason to believe or suggest this is a widespread problem. I believe two or maybe three titles including "The Prestige" and "Stranger Than Fiction" have been affected with the majority of AVS members reporting no problem whatsoever with those or any other titles for that matter.
post #168 of 397
I've heard of disc rot before, but I just don't get what people do to their discs to make it happen. Even my brother is not that careless with discs.
post #169 of 397
CD/DVD rot can happen if left in extremely humid and salty environments, DVD delamination occurs simply because of manufacturing problems with the way the two layers are joined together.
This Blu-ray rot is something similar to the latter, some manufacturing problem which destabilizes over time.
I have been afflicted by it and I am extremely careful with all my discs, which dont even have a finger print on any of them and are stored in a low-humidity controlled room. Repeat: Its not mistreatment, its a manufacturing fault.
post #170 of 397
I am really concerned about long term stability of Blu-ray discs if we are seeing this kind of defect after only a few months.
post #171 of 397
In the dozens of media forums I visit daily, I can count on just one hand the number of people that have reported a problem with their Blu-ray discs. I have a minimal amount of concern at this point. My real concern is that this subject is monitored closely to avoid the sickness of fanboyism from infecting this thread in order to exploit a rather isolated occurance into an indictment of an entire format. AVS Forum already has a somewhat negative reputation in some quarters because of this type of juvenile behavior.
post #172 of 397
My Departed looked fine, as did The Descent. I didn'tsee anything on my others.
same for me
post #173 of 397
Have you guys run into this?
BD10 FW 1.1, My Departed BD played fine.
After FW 2 and 2.1 it does not READ anymore, BD10 just goes to STOP after 30 seconds or so of trying to read. Checked the disc for Rot and looks clean/clear.
Has anyone run into this?
I'm using a HDMI (video only) and Optical digital (audio) out.
DEPARTED: BVDL-007000B1 10
Thanks much for any ideas!
Cheers m8s!
post #174 of 397
Originally Posted by MaxDam77 View Post
Ok I just got home and it took me like 4 tries to finally be able to watch it but it freezes.
Here is the pic of my Prestige BD:
Wow. I checked all my Blu-ray discs (have over 60) and none of them have this problem. They are all pristine. Several years ago I accidentally left some DVDs out very near to where I was painting a wall with a roller brush. And guess what? They ended up looking exactly like this picture. I was always more careful with my DVDs after that.
If you sprinkled cinnamon on a disc it would probably look like that also. Of course, if you accidentally sprinkle cinnamon on one of your discs, just blow it off & it will be fine.
And if you "accidentally" spatter paint or sprinkle cinnamon on an HD-DVD disc, take a picture of it, post a picture of the disc on the HD-DVD forums and tell the world you've discovered HD-DVD Disc Rot.
post #175 of 397
I just checked all of my BD50s (including Prestige and Departed) and none of them had a speck on them. I really hope this is limited in scope..
post #176 of 397
That sounds delicious.
post #177 of 397
no, not even on the prestige
post #178 of 397
Already a thread on this. please continue discussion there.
http://www.avsforum.com/avs-vb/showthread.php?t=857067
post #179 of 397
Threads reported & merged!
post #180 of 397
Sony DADC strikes again! It looks like they have not learned from their past mistakes in LaserDisc manufacturing.
  Back to Forum: Blu-ray Software
This thread is locked
