AVS › AVS Forum › Audio › Surround Music Formats › HDMI to TV, then Optical from TV to receiver?
post #1 of 7
Okay, I am trying to set this up right tonight. I have a Receiver which can do 5.1 surround sound. and has optical inputs, but not HDMI (so I can't use it to control the video unless I used SVIDEO or rca). I have HD tv, so I want HDMI.
I guess my question is, can I use my TV as a pass-through, so Video and Audio go to the TV using the HDMI, and then I use the TV-optical-out to go to the receiver? I don't know if I'll lose audio quality versus just going from the components to the receiver.
I'd prefer to go through the tv, so I have one less switch to change when I want to switch devices I'm watching.
post #2 of 7
Just to clarify, my TV is a Samsung HL-S6187W
post #3 of 7
I think you are better off minimizing the pass-throughs. I would have thought that most sources would have optical/coax digital audio in addition to HDMI. If is the case, then run HDMI from your source to the TV and optical also from the source to your receiver.
post #4 of 7
The tv will not pass through 5:1 - it will come out as 2:1
post #5 of 7
Oh, I didn't realize that. I guess I'll go optical audio to the receiver, and just have to switch that and the tv when I want to change from dvd to regular tv/tivo.
post #6 of 7
If you want to minimize the amount of input switching, you should really consider a universal remote like the Logitech Harmony or URC remotes.
post #7 of 7
HD can be passed via a component video connection, as well.
  Back to Forum: Surround Music Formats
