I have a few quick questions that I was hoping I could get some input on.
1) I have an ATI AIW X600 Pro, would this card be ok for displaying DVD's (not HD-DVD or Blu Ray) on a 1080p Westy monitor or should I upgrade to something newer? Is there one particular model line that is known for the best DVD upscaling?
2) I really only need basic PVR functionality, I only really watch a few shows on a regular basis and I like to channel hop; I've played with MediaPortal but I find that is sometimes is slow to change channels; is there a software package that is a bit quicker?
3) Has anyone here had any luck with the HDHomeRun? What about recording using this device, does it require a lot of CPU power?
4) I was thinking of building a Mini-Itx mobo into my tv cabinet for a lower power PVR / FrontEnd. The board that I am looking at runs at 1.5Ghz has DVI and can output 1920x1080 @ 60Hz. Anyone think this may be an issue as far as peformance, it would probably have a Happauge PVR-150 installed and thats about it for SD Tv tuning?
I don't have a problem installing / swapping applications etc but I don't want to end up with a bunch of useless hardware so any help would be appreciated.
Tom
Tom
