I'm of the opinion that the server software one uses is as important (if not more) than the actual media extender chosen. That said, I'd like to get a master list of different server software and the pros and cons of each, perhaps something we can use as a sticky.
I'd like to avoid any Apple flames; I know many people who use iTunes and love it, and just because it doesn't work for me doesn't mean that I don't think it's a legitimate choice for others; one needs to weigh the pros and cons.
I'd also like to avoid any XBMC flames; I know many people who use XBMC and love it, and just because it doesn't work for me doesn't mean that I don't think it's a legitimate choice for others; one needs to weigh the pros and cons.
I'll start out with what I've tried (disclaimer: I'm currently using Tversity). Feel free to correct me if what I've written is incorrect. I'll change/add to this list as others post.
Basic File Server
Platform: Windows; Linux; Mac
Pros: Included with Most Operating Systems; No (little) Configuration Needed
Cons: No (little) Configuration Possible; Few Media Extenders Can Use; Requires Beefy Media Extender, Such as XBMC or HTPC.
D-Link Media Server
Platform: Windows
Pros: Free; Easy-to-Use; UPnP
Cons: Limited Functionality; Buggy; Doesn't Run as a Service; Sorts Album Tracks Alphabetically
Firefly
Platform: Windows; Linux; FreeBSD; AIX; Solaris
Pros: Free; Runs as a Service; Plays iTunes, Including Apple Lossless; Transcodes
Cons: Not UPnP
FUPPES
Platform: Linux; Windows; FreeBSD
Pros: Free; Transcodes
Cons: Not Fully UPnP-Compliant Yet; No Mac Support
GMediaServer
Platform: Linux; FreeBSD
Pros: Free; UPnP; Easy to use web based UI
Cons: No Windows or Mac; Larger Collections Take More Memory; Doesn't Appear to Transcode
iTunes
Platform: Windows, Mac
Pros: Free; Ubiquitous; Built-in Media Store; Easy-to-Use; Windows or Mac
Cons: Doesn't Run as a Service; Doesn't Work with UPnP Devices
Nero MediaHome
Platform: Windows
Pros: Bundled with Nero Burning Software
Cons: Not Free; Windows Only
JRiver Media Center
Platform: Windows
Pros: UPnP; Advanced Library Features; "Theater View" With HTPC; Works With iPod (and other devices); Transcodes
Cons: Not Free; Windows Only; Doesn't Run as a Service
SwissCenter
Platform: Windows; Mac; Linux; NetBSD; NAS
Pros: Free; Integrates With MusicIP; Controls for Paging Through Large Collections; Appears to be UPnP
Cons: ???
Tversity
Platform: Windows Only
Pros: Free; UPnP; Many International TV Feeds Built-In; Runs as a Service; Transcodes On-The-Fly
Cons: Crashes when a User Logs Off the Server; Still a "Work in Progress"; Menu Structure Not Customizable; Doesn't Play Protected Content; Difficult to Work With iTunes; Windows Only
Twonky
Pros: Runs as a Service; UPnP; Rock Solid; Customizable Menu Structure; Windows, Mac or Linux
Cons: Not Free; Doesn't Play Protected Content; Difficult to Work With iTunes
uShare
Platform: Linux; FreeBSD; FreeNAS
Pros: Free; UPnP; Easy to use web based UI; Included with FreeNAS
Cons: No Windows or Mac; Larger Collections Take More Memory; Doesn't Appear to Transcode; Doesn't Read All Tags Correctly
ViiV
Windows Media Connect
Platform: Windows
Pros: Free; Plays Protected WMAs
Cons: Windows XP and Vista Only; Not UPnP
Windows Media Player 11
Platform: Windows XP, Vista
Pros: Free; UPnP; Plays Protected WMAs
WIZD
Platform: Windows, Linux
Pros: Free, open source, compatible with Windows OS, Linux and NAS, easy to setup, low memory usage, no restrictions on the number of drives/folders/files, no restrictions on root directories, provides capabilities like playing ISO, VOB, file deletion, customizable skins and menu, ts file play, DV avi file play, does not hang up, runs solid day in and day out, runs as a service; Windows or Linux
Cons: The GUI could be a bit better, no NFS, does not play protected content, not UPnP
Basic File Server
D-Link Media Server
Platform: Windows
Firefly
Cons: Not UPnP
FUPPES
GMediaServer
iTunes
Nero MediaHome
Platform: Windows
JRiver Media Center
Platform: Windows
SwissCenter
Cons: ???
Tversity
Twonky
uShare
ViiV
Platform: Windows
WIZD
