AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 8G KURO Owner's Discussions Thread
The Official Pioneer 8G KURO Owner's Discussions Thread - Page 343
post #10261 of 17517
Originally Posted by 1080pixel View Post
Specically what is wrong with the signal...
The station appears to be allowing some of the visual "garbage" on the edge of the transmission (cc signals, etc.) to intrude into the "safe zone," rather than confining it to the area normally removed by overscan.
post #10262 of 17517
Originally Posted by LesMoss View Post
But, that audio processing circuitry is already there in the KUROs to handle DD5.1 from the OTA tuner.
But it is a very poor design.
no, that circuitry isn't already there, they merely passthrough ota dd 5.1... if you attempted to pass audio via hdmi out through the digital port, you'd have to handle downmixing pcm, etc...
it may or may not be poor design. but it isn't unique to pio. they all work that way.
post #10263 of 17517
Originally Posted by Macfan424 View Post
I can get rid of it by changing the screen's position via the "H/V Position Adjust control, but this would make the screen off center for all channels, so I just live with it on FXHD. Hopefully, the originators will improve their transmission quality as they gain experience with HD.
I thought so too but adjusting vertical position did not work for me. Pioneer confirmed with my finding too. Three different Pio techs told me it's the "signal".
post #10264 of 17517
I included the pix of the white lines at the top edge of the video display area on my 5010. I have DirecTV HD service. HDMI straight from HD receiver to TV.
The line is broken into segments. Some segments flash on and off very fast.
It happens mostly during commercial although I saw it with a National Geo Channel program where there were pillars on left and right.
I also see it on the left edge of the video display area of a 4:3 signal signal.
DirecTV has no idea. Pioneer says it's the signal from DirecTV.
Any idea? Thanks.
I was getting the same thing with a Verizon FIOS feed. I adjusted the vertical position of the image upward 8 clicks and I have not had any more appearances of the broken white lines flashing at the top, nor the bottom of my set. Also, I recorded the HD NET test pattern signal a few weeks ago and checked the position of my set's image with that and surprise surprise the image position was perfect by that standard.
post #10265 of 17517
yup. this is correct. since there's so little overscan on your set, you get stuff like that... it's noticeable on football games on fox as well... you'll also notice on fox games that sometimes the score bug on the top has a gap between it and the top of the screen...
post #10266 of 17517
I will be wall mounting my 50" Kuro. My bracket is fixed no tilt/etc. Does 30" from the floor to the bottom of the plasma sound about right? I am not looking for the over the fireplace/painting look.
post #10267 of 17517
well... I gave it a try again. Adjusted 8 clicks upward but same problem.
post #10268 of 17517
Any idea? Thanks.
It's Called a Data transmission segment. It shows up all TV's That have near Zero overscan. Now ways to get it to go away:
1. Adjust Overscan (But this will delete some of the information in the picture on all channels it is not present on, not just the few you see it on)
2.Raise vertical position. Same drawbacks as above listed in #1 and sometimes this won't remove all of it.
3. Live with it ( I do on mine)
I have a family member that just bought a Sony XBR4 LCD. Saw it on his and had to explain what it was so he wouldn't be freakin out and calling me everytime he saw it.
Trying to give you the most and best picture on HD and HD DVD has caused some problems in the transmission area of the picture. But it is only on a few.
post #10269 of 17517
I would suggest 21" to 24" from the floor to the bottom of the display unless you will be sitting in a recliner. That will put your eye in the middle third of the screen from a sitting position.
Enjoy your new Kuro.
Mike
post #10270 of 17517
The tearing line at the top of the screen is caused by the TV station. What you're seeing is called the "vertical interval" Broadcasters sell this space for all sorts of uses. For example CW sells this bandwidth to Muzak and puts the Muzak audio in the "vertical interval" as a sub-carrier.
Call the station and your programming carrier so they can take care of this transmission error.
-Robert
post #10271 of 17517
Any idea? Thanks.
That's due to relative underscan on your set (compared to the usual 3-4percent, it's less). This is a good thing in most instances as you end up seeing more of the picture. It's not a defect. If your D* receiver allows it, double check the centering of your image and adjust if necessary.
post #10272 of 17517
-Robert
this problem seems to happen more on Nat Geographic Channel HD than others.
Although I see it with non-HD commercials during local ABC News HD.
So in the case of National Geographic Channel, who is the "station" and who is the "programming carrier"? Sorry if this question is too trivia.
post #10273 of 17517
Originally Posted by RoyG View Post
That is the beauty of the Harmony remotes. You don't need discrete codes for it to work. I have the 890 and it cycles through the differant modes to reach the one I choose , i.e. video 1 for DTV and componet for DVDs (Obviously not a Kuro, but soon). As long as you always use the Harmony it remembers what state the equipmet is in and only changes what needs to be changed when you select watch TV or watch DVD etc.
I have a Harmony (the 880). I have discrete codes for the inputs, that wasn't what we were talking about. What I am lacking is discrete codes for the image configuration data. Cycling doesn't really solve the problem, because that's not something the Harmony is trying to track.
post #10274 of 17517
A question for every HD plasma owner with a HD DVD player.
I have the Toshiba XA2. It gives me a choice of picture settings. I'm sure yours does also. They are 16x9, 4:3, and 4:3 letterbox. My question is this... if you set the DVD player to 16x9 and the aspect ratio of the movie is 2.35:1 (or 2.66:1 in the case of Ben Hur) aren't you going to cause distortion of the picture to some degree using the 16x9 setting?
It seems to me you would have to set the player to the letterbox format to get the identical aspect ratio of the movie.
I've only had this plasma and DVD player for 3 weeks so I haven't watched a lot of movies but the ones I've seen I have to say I don't notice any distortion when in the 16x9 setting and playing a movie with a 2.35:1 aspect ratio but it seems to me there has to be some distortion to some degree. Am I wrong?
All experiences and opinions on this are welcome. I would prefer to minimize the distortion of the original aspect ratio of movies.
post #10275 of 17517
nope. 16X9 setting is telling your hddvd player that you have 16X9 set vs. a 4X3 set.
you aren't noticing any distortion because it isn't causing any.
post #10276 of 17517
You want the aspect ratio at 16X9 because your display is 16X9 regardless of the aspect ration of the source. Movies @ 2.35:1 will display with horizontal bars at the top and bottom and that is correct.
post #10277 of 17517
I'll be receiving my 50 inch 110FD next week. What are the dimensions of it's pedestal stand? (length and depth)
post #10278 of 17517
Any idea? Thanks.
I saw a white line down the left side while watching the Today show on 2 consecutive days. I also saw it on a newscast on one of the nights at the same OTA station.
It disappeared and I suspect it was a transmission problem on the local level. There is a horz and vert adjustment for the picture but only on AV inputs.
post #10279 of 17517
I'd agree with Pioneer. Partially, at least. I'd guess the fault is with the originating station, not D* per se. I see the same thing, but only with FXHD, not the other channels I watch. It comes and goes as the orbiter moves the picture. My hookup is like yours, using an HR20 D* receiver.
I have that problem also but only see it on FXHD. it is definetly D* and i'm kinda used to it by now. i record Nip Tuck for my wife and whenever we watch it that dam line at the top of the screen comes up. I'm useing the HR21.
post #10280 of 17517
From my research, most will say the middle of the plasma should be no higher than the avg persons eyesight height. Lets say thats approx. 64.5 inches. Therefore the middle of a plasma should be 64.5" from the floor. A 60" Kuro is 35" high so subtract (1/2) 17.5 from 64.5 which equals 47" (floor to bottom of plasma).
Personally I think thats a little to high for wall mounting. Most people will have a credenza underneath and an in-wall center channel speaker. Both need accomadating. I have a cardboard cutout for the pro150 and its at 48" bottom. My wife agrees that it needs to be set a little lower and we decided that about 44" is ideal for us. I have a rather large room which also influenced our decision. Regards...
post #10281 of 17517
Hello everyone,
I'm not sure where I was reading this, but some posters in this forum where stating that it was possible to use the 150FD stand on the 6010FD. This would be great if it could be done as it would lower the TV for those that can't mount it and are not using the speakers. Anyone try it or know of this and can confirm? Thanks.
post #10282 of 17517
what i did was stand up and look straight at the wall. i then put a mark on the wall and hung my tv there. i found it to be a great method to mounting my 50". it's perfect when i'm sitting and standing. i don't get the neck aches when i'm sitting and when big plays happen during sports and i get all freaked out and jump out of my seat the picture still stays at a perfect height. i'm a little over 6'.
post #10283 of 17517
Any idea? Thanks.
I have the exact same thing when I use dot-to-dot mode on 1080i source
with my RogersTV (Scientific Atlanta) box. It goes away if I either go for
720P or set the TV to FULL MODE (The box sets itself to output at either
1080i or 720P). It also fluctuates based on stations.
post #10284 of 17517
Hello All,
I just recently got my 5010FD and it is absolutely incredible. I was told by someone that its a good idea to to get a powerconditioner/surge protector as opposed to just a surge protector as I would notice a difference in picture quality. I have seen(or should I say I've heard) the difference a power conditioner can make for audio quality, but can anyone speak from experience when it comes to picture quality? If it is indeed worth it, does anyone recommend any particular conditioner?
post #10285 of 17517
After hearing what others are saying about the scan lines I asked about earlier, I wonder if it will be fruitful to pursue with DirecTV.
The tech is coming out in a few days. Is there anything he/DirecTV can do?
What about the video/audio out-of-sync problem I experience with the 4 major networks - especially prime time shows? Again, can DirecTV do anything about it while the tech is on site? I hook directly from HD receiver to the TV via HDMI.
post #10286 of 17517
Greetings from Canada.
I have been following this thread, as well as some others, for a couple of months now. Some great questions/answers from the users here.
I am hoping to purchase a new plasma during the boxing week sales. I have been going back and forth between the Panasonic and the Pioneer for some time. The stores that have both all seem to agree that the Pioneer is the way to go. It has taken a long time for our pricing to come down in Canada (even though our dollar is now at par with the US dollar). The Pioneer 6010 is now in my budget range, but to be honest the number of issues that users have reported on this thread have me a bit nervous. There seems to be more problems with the Pioneers than reported with the Panasonics. Perhaps there is a negative slant to most postings because people don't need to post if everything is working properly.
OK - my questions
Is the 6010 worth the extra $ compared to the Panasonic?
Are the Panasonic units more reliable?
Will SD DVDs appear pixilated on a screen this large? The stores always demo with Blu-Ray, and the one demo I did see with a standard DVD (played in the Pioneer BD) looked a bit pixilated.
Any thoughts on extended warranties?
post #10287 of 17517
OK - my questions
DVD's will look almost HD with the 6010 and a decent upconverting player. I have had zero issues with my 6010. I think some people go looking for issues that they would never see in actual use. Overall I think the 8g Kuro's are some of the most liked panels ever made. I didn't even look at the Panny so I can't compare it.
post #10288 of 17517
Hmm, it appears opinions on correct height are divided, 21" to 24" and 44" to 47" which means I am somewhere in the middle with 30" and I think that's what I will go for. If it doesn't work out I guess I could reposition it and repaint the wall again.
post #10289 of 17517
I wouldn't call them scan lines. They are edge artifacts due to relative underscan. DirectTV can't do a thing and good luck getting any particular station to listen. Your best bet is to adjust image position as needed through the D*reciever and/or ignore it. It doesn't happen with HD programming at all in my experience and it doesn't happen when an SD image is stretched using FULL or WIDE.
Lipsync problems are largely a result of larger displays (you're able to see it now when you didn't before). They are variable in nature and again there likely isn't much you can do. There are aftermarket devices (or AVR's will do it) to delay the audio for you but if it is not a consistent thing you will end up chasing your tail.
post #10290 of 17517
Originally Posted by bboncorr1 View Post
what i did was stand up and look straight at the wall. i then put a mark on the wall and hung my tv there. i found it to be a great method to mounting my 50". it's perfect when i'm sitting and standing. ...
You watch your TV while standing?
