Originally Posted by
D-Nice
Recommended (which means it's OPTIONAL!!!!) 150 Hour Break-In settings for Pioneer 4280/5080/5010FD/6010FD/Elite 950/1150/110FD/150FD (ONLY to be used with Evangelo2's Break-in DVD and a DVD player!!! DO NOT USE THESE SETTINGS WITH ANY OTHER DVD, CABLE BOX, SAT BOX, ETC!!!!!!!!!!)
Main Menu:
AV Selection: Standard
Contrast: 50
Brightness: -2
Color: +15
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Picture Detail:
DRE Picture: High
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 3
Color Detail:
Color Temp: High
CTI: Off
Noise Reduction:
DNR: Off
Field NR: Off
Power Save Mode: Off
Orbiter: On
Hi there guys!
My name is Alexander and I live in Brazil at the moment and I have recently decided to buy a PDP5010FD after reading and seeing some of the posts at the forum pages.
The problem is that here in Brazil, things are more complicated to get than it is at the US. As an example, I have bought this Pioneer plasma almost 3 months ago and only today I have received it here in my home.
As you can imagine, that just makes things not as easy for repairs of exchanges as it would be if I were in the US.
That being said, can I get some help with setting up my PDP5010FD? Which of D-Nice's settings is the most updated one for the Break-in settings and also is there anything that any of you might find that would be important for the first hours of use?
From what I have seen, everything looks fine with the display. No dead pixels or any other factory defect. I have watched 2 or 3 minutes of a Blue Ray disc and from what I have seen, everything seems ok. That is very good for me: It means I won't have to go over the tremendous trouble of sending it back to the US for warranty or service. I bought it at Invision Displays and imported it myself.
Best regards,
