Originally Posted by E-A-G-L-E-S
Makes sense, not that you need to qualify yourself or your services, as they are known to be great..
To play devil's advocate though, some people are more interested in video than audio and vice versa. Also, it 'seems' that a user 'can' tweak their sound more and easier than calibrating their display correctly.
You are highly mistaken about the audio being easier. It is actually the opposite. It is much harder to get correct. The number of errors that can result in horrible sound are numerous and easy to make without a thorough and accurate test procedure. You would be stunned if you knew the half of it.
compared to the precision meter of UMR.
Should I take it back and swap it for another or live with as is?
