Originally Posted by
gbr1ryder
The game on CBS was broadcasted at 1080i and Fox at 720p. I have always noticed the fox games have a more crisp picture. I have also heard that sports usually look better at a 720p resolution than any other. I didn't even adjust the cable box to reflect the 720p resolution i just left it at 1080i and looked freakin awesome. btw, I have the 5010 just to give you an idea.
generally speaking, the pq on cbs (1080i) is superior for sports to anything else... espn/espn2(720p) varies, but at it's best can be close to cbs... fox(720p) varies GREATLY, but again, at it's best (which is rare) can be close to cbs... nbc(1080i) is generally bad (although improved considerably towards the end of football season)... if you spend a bit of time haunting the hdtv programming threads, you'll find this to be true...
something to keep in mind... your provider plays a BIG factor in what you see on your set... again
generally speaking, fios is the best, followed by cable/d* mpeg4, then d* mpeg2, then dish (leaving aside ota)... also, your local affiliate can also affect your picture quality...
there's a lot that happens inbetween the production truck and your tv set...
fwiw, if you don't adjust your cable box to pass through native resolution, you are letting the cable box scale instead of your set.
