AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › Outdoor HDMI/Component Cable
post #1 of 4
Hello, this is my first post on this forum. I just bought a projector (IN72) for occasional use outdoors to show dvds and TV and plan to purchase and permanently install a 50 foot HDMI or Component video cable to run from my equipment inside the house to the projector outside.
In consideration of weather and the elements, will a thick 24 awg HDMI cable or any component cable work for an outdoor home theater setup? Any advice would be helpful. Thanks.
post #2 of 4
im looking to do the same thing, anyone?
post #3 of 4
The best signal in, will give you the best picture out.
If you go the component cable route, try here, they are a forum sponsor:
http://www.ramelectronics.net/html/comp-video.html
post #4 of 4
I use HDMI cables with my set up. It just makes it a lot easier. One for the HD DVD player and one for the Blu ray player. Both go into my Onkyo 605 and then of course a HDMI out from there goes into my Sanyo Z5... It is almost like cheating!
  Back to Forum: Outdoor Theaters
