Ok so this is a little different. i did a search,couldnt find anything.
Here it is. I went to an auction and picked up a few plasmas.
2 42"NEC's and 2 60" Zenith Plasmas.
Heres the problem, They have some REALLY BAD burn in. COuldnt check before hand of course. but thats the risk you take.
Anyway is there any fix or am i out cash?
I was thinking is there a program that inverses an image? they were used as bank dispays i found out when i got them home, The burn in is Some commerce bank logos and about saving with a home equity loan
is there anything ican do?Someone i can pay to fix them?
no bad pixels or anything,Just this horrendous burn in. If i look in the sunlight i can see the burn in. In theory inversing the image should work right?
Argh. Someone help me out
These plasmas were SO ABUSED
