AVS › AVS Forum › Video Components › Home Theater Computers › Promise SMARTSTOR NS4300N
Promise SMARTSTOR NS4300N - Page 23
post #661 of 667
Sorry your in this boat, I have had 3 of them 2 ram's 1 for of was an upgrade to a newer version.
The hardware is slow and the software is really buggy they never really kept up on bug fixes. I sold mine. Bought something better more popular. So if the hardware crashes I can pick up another one and get my data back. Call again and ask for a more knowable person who can tell you if you can put the drives in another scsi box and see this raid. I have never tried that but could have as I had lots of servers that ran different cards for the scsi raid setup.
Their is also a guy that works for promise that used to post here but not any more. I think his name was Billy.
Good luck
post #662 of 667
I've been using mine on companies domain that used Windows 2003 Server for domain controller.
They recently upgraded to 2008 R2, and now although the box can still join the domain, user authentication fails so nobody can actually get to their files.
I contacted Promise Support and they (eventually) said 2008R2 isn't supported.
While waiting 2 weeks for Promise Support to "contact his lead", I tried to figure out possible cause of problem myself. Apparently it may be related to 2008R2 using SMB2 or something, requiring newer version of Samba on the NAS. Promise was able to tell me it uses Samba 3.0.26. From what I can find online, that was one of the first versions to support smb2 and it was still imperfect, so I think one possible solution would be to upgrade samba in the NAS.
Anyone know any possible way I could do that? Or have any other ideas how to make this thing work with 2008R2 domain controller?
post #663 of 667
Hello, we got ther the same Problem. The Active Directory Authentication works with Windows XP, but not with Windows 7.
I have rootet my NAS an now i can see sow errors.
switch message SMBsesssetupX (pid 3566) conn 0x0
setting sec ctx (0, 0) - sec_ctx_stack_ndx = 0
NT user token: (NULL)
UNIX token of user 0
Primary group is 0 and contains 0 supplementary groups
change_to_root_user: now uid=(0,0) gid=(0,0)
wct=12 flg2=0xc807
setup_new_vc_session: New VC == 0, if NT4.x compatible we would close all old resources.
Doing spnego session setup
NativeOS=[] NativeLanMan=[] PrimaryDomain=[]
Got user=[DUMMYUSER] domain=[DOMAINNTNETZWERK] workstation=[DUMMYWS-W7] len1=24 len2=296
make_user_info_map: Mapping user [DOMAINNTNETZWERK]\[DUMMYUSER] from workstation [DUMMYWS-W7]
attempting to make a user_info for DUMMYUSER (Dummy User)
making strings for Dummyuser's user_info struct
making blobs for Dummyusers's user_info struct
check_ntlm_password: Checking password for unmapped user [DOMAINNTNETZWERK]\[DUMMYUSER]@[DUMMYWS-W7] with the new password interface
check_ntlm_password: mapped user is: [DOMAINNTNETZWERK]\[DUMMYUSER]@[DUMMYWS-W7]
[000] 20 20 81 1B 23 59 80 D4 ..#Y..
push_sec_ctx(0, 0) : sec_ctx_stack_ndx = 1
push_conn_ctx(0) : conn_ctx_stack_ndx = 0
setting sec ctx (0, 0) - sec_ctx_stack_ndx = 1
pop_sec_ctx (0, 0) - sec_ctx_stack_ndx = 0
check_ntlm_password: winbind authentication for user [DUMMYUSER] FAILED with error NT_STATUS_WRONG_PASSWORD
check_ntlm_password: Authentication for user [DUMMYUSER] -> [DUMMYUSER] FAILED with error NT_STATUS_WRONG_PASSWORD
attempting to free (and zero) a user_info structure
error packet at smbd/sesssetup.c(105) cmd=115 (SMBsesssetupX) NT_STATUS_LOGON_FAILURE
size=35
[admin@edv-nas]# sudo ./smbd --version
Version 3.0.31
It seems that the Version is not compatible with Windows 7
post #664 of 667
I have a Promise SmartStor NS4300N. Somehow, it seems as if all the files on the NAS have suddenly become owned exclusively by the user root, and group admin. This may have been because the account used to map the network drive to the local PCs was deleted when the ownership of the NAS changed. ... the other users that were in that group, however, who remained as owners did not retain access.
Is there any way to solve this problem? Do I have to hack into the NAS and root it?
post #665 of 667
I had a power failure which resulted in my folders inaccessible. After a few days the folders disappeared then the volume was gone as well. I have been going back and fourth with Promise technical support off and on for a year now trying to get my data off. In September I bought an additional Promise NAS ns4300n box and it worked till I let tech support into it. I've lost two boxes trying to resurrect my data from system corruption via tech support. I know the guys on this side are just trying to help and I don't want to bash anything but why was this solution so easy but not prevelant in any of all the NAS box posts of and I really hope this works for you. Make sure if you follow the tutorial. Use Ubuntu 12.04 as the 12.10 doesn't have the Disk Utility it only has disk which didn't work for me. I didn't need any of the final steps after I installed the raid support, it found my array immediately. 799gb restored from two WD Blacks in Raid0. I just looked at the last file I copied was from November of 2011. Don't give up hope.
http://forum.synology.com/enu/viewtopic.php?f=160&t=51393
post #666 of 667
Originally Posted by PromiseNasDude View Post
DLNA Plugin Version 01.02.0000.01_A5 is now available for NS4300/NS2300. Resolves the inability to delete contents of .thumbs folder.
Remember, the .thumbs folder is created by Windows. The inability to delete contents of .thumbs folder is the issue resolved. Other small DLNA fixes are included. Final Release to come in a few weeks (DVT is in progress).
ftp://209.172.106.110
username/password: dlnabeta/dlnabeta
Remove old Plugin, then install latest! Final Release is a few weeks away.
Also, check out our new website @ www.promise.com. New SmartStor Forum will go LIVE in a few weeks.
Stay tuned..
I missed this plugin update. Anybody has a copy? Thanks!
post #667 of 667
Hi,
i have a SmartStor NS4300N.
It seam it is simillar to the NUUO NVR Mini.
I will change my NS4300N to an NUUO NVR Mini.
It is possible?
I have test du flash the NS4300N with the NUUO NVR Mini FirmWare, but it works not with the SmartStore WebFrontEnd.
The Meassage is:
Does anywere Know how I can flash the NUUO NVR Mini FirmWare over telent or an other way?
By !
