AVS › AVS Forum › Video Components › Home Theater Computers › Samsung LE-40M61B - DVI/HDMI connection
post #1 of 5
I've been looking for a solution to this for a long time, as it's really annoying that I can't get this to work. Has anyone successfully connected their HTPC to the Samsung LE-40M61B TV over the HDMI-connection?
I have tried, but the picture is either too small or too large. It seems the TV will only accept standard resolutions like 720P, 1080P etc. Since the TV is 768*1366, this will not work. Is there a workaround that does not include too much tweaking with Powerstrip etc.?
post #2 of 5
what OS and what video card?
- Josh
post #3 of 5
Hdmi will only accept limited resolutions, you should refer to your manual.
I have a LEM86BD
Via hdmi, 60hz shows underscan, 70 hz doesnt, but i think that is a problem with the ati drivers.
Make sure you know what your tv supports and then config powerstrip exactly, if you need to and you card supports it
post #4 of 5
- Josh
I use Windows XP MCE and Nvidia 7600GT.
post #5 of 5
ok then, if you go into the advanced menu system, there is an overscan compensation tool that you can use to fix the resolution issues, and basically negates the need for powerstrip.
- Josh
