AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › CMRA's S-I-L-V-E-R solution starts here:
CMRA's S-I-L-V-E-R solution starts here: - Page 11
post #301 of 618
Originally Posted by DevonS View Post
I suck with the pics. Using the flash obliterates the image completely... even in 'macro' mode. No flash with the big-ass halogen work light makes that yellow thingy. Even with white balance on, 400ISO etc.
You can get a Whibal card, and then manually set the white balance on your camera for the current lighting conditions. This is true for what I'd consider mid-range and up point-and-shoot digital cameras, at least. You'd have to read your camera manual to see (1) if it does it, and (2) the procedure to manually set the white balance using a reference (like the Whibal cards). Just google "Whibal" and you'll learn all you need to know.
post #302 of 618
Originally Posted by Harpmaker View Post
Here is the texture pic with the color cast neutralized. I didn't get it perfect by any means, but I hope it helps.
Thanks, mech. That definitely looks better.
post #303 of 618
Originally Posted by cynical2 View Post
Well, comparing the texture side-by-side between the two, if anything I'd say that your screen has less texture than CMRA's. Clearly the white balance is off in the picture you took, but I think texture can still be effectively judged.
My bet would be that texture isn't the problem...
I couldn't agree more. In fact, the spray looks excellent. You may want to share your technique, Devon.
The culprit lays elsewhere, methinks.
post #304 of 618
That would be harpmaker my good man!
mech
post #305 of 618
I think the culprit lies in not enough paint. The pictures may show a nice even surface with little texture, but to the naked eye you could make out patches or dots of silver particulate. I've sprayed an additional 4 coats, paying special attention to being 12 inches away, overlapping properly and slowing down a bit. I re-evaluated King Kong and was very surprised. Maybe the improvement is in my head, but as long as I perceive an improvement that's all that matters to me.
Keep in mind, this has absolutely no scientific bearing and no evidence to support it, but my theory is that since the silver metalic flakes were grouped unevenly, those groups were 'shining' (or hotspotting) ever so slightly as to overpower the rest of the screen where the silver flakes were less distributed. Now that the flakes are more evenly applied, the whole screen shines together. It appears that my misty problems are gone, along with some of the graininess. I still see some sparkly/hotspotty stuff in bright areas, such as a bright blue sky. I'm going to apply 1 or 2 additional coats and get some shots for comparison... even though my skills with a camera seem to be even worse than my paint sprayer skills... if you can imagine that
post #306 of 618
mech
Oooops...thanks harpmaker!
post #307 of 618
He does fall asleep during the movie alot. Make that everytime. You have that on good authority. Mine. Eye witness testimony.
I couldn't resist.
FWIW, MM watched the whole movie (twice) this time. Was it the screen? The projector? Or, just Charlize Theron? Hmmmm...I may never know.
post #308 of 618
No worries! Glad it helped.
post #309 of 618
I believe I'm finished. At this point I really have no choice since we just got the new carpet installed and if I even look at the paint sprayer now, my wife may very well make me sleep in the garage. All told, I think I put on about 18-20 light coats, but I'll admit that the first 10 were so light they probably equated to about 3 effective coats. I painted up a small strip of MDF with just primer to have something to compare, spring-clamped it to the screen and when I pulled it off the next morning I had a chunk of the MDF stuck to my screen Had to scrape and spot sand the little bitch and try to blend it in. Turned out ok. I occaisionally notice a small spot that looks dirty at the very top of the screen. Only even comes into play if the media is 16:9 anyway.
I'm sure I could have put down another coat or two, but I'm happy with where it is now. Some things seem to get kind of misty (darker scene with, say, a lamp in the corner) but that could be a combination of the projector, calibration and screen.
It is really quite amazing when you watch a movie and actually forget to look for problems, how stunning it actually is. That's one thing I've noticed abundantly on these forums. Way too many guys getting lost in the minutia of tweaking this, analyzing that, taking tests and comparisons and reading thousands of posts and never really enjoying this expensive-ass hobby.
I think I'll go watch a movie now. Maybe I'll plug in some of my sorry-ass screenies later in the week!
post #310 of 618
Well said by the guy who sprayed on 20 coats!
post #311 of 618
Try boating!
post #312 of 618
I forgot to mention the 5 primer coats too
Yes, I too got caught in the details
post #313 of 618
Devon, thanks for the update. What is wrong with your screenies?
post #314 of 618
Not sure. I just suck with a camera apparently. They just look crappy. I have a tripod and I zoom in etc, but the pics seem skewed somehow. The top of the pic looks arched, everything looks fuzzier than the actual image on screen etc. Just gotta practice and play with camera settings I guess. I posted a couple shots earlier in this thread, so you can see what I mean.
post #315 of 618
Not sure. I just suck with a camera apparently. .
Sometimes, I think I know the feeling. They just don't come out right all the time.
Anyway, here's a link to a few 'just for fun'. I have to figure out what the BIG Boys know. They get some real eye candy.
http://www.avsforum.com/avs-vb/showp...&postcount=733
http://www.avsforum.com/avs-vb/showt...2#post12049492
post #316 of 618
I thought it could be that easy too. When ALL my digicams made the images too contrasty, crushing blacks, and blowing out highlights I did a little homework.
The best routine so far is to shoot in the RAW mode (better digicams support this feature) and rework the image in software (often photoshop) before posting.
I only have ONE camera that supports RAW. I may give it a GO after I learn more.
post #317 of 618
CMRA,
Could you summarize one more time what the difference in the ingredients is between S-I-L-V-E-R vs SilverHG.
post #318 of 618
Originally Posted by Pablo M View Post
CMRA,
Only the silver changes. Behr SM, widely available at HD, is the original. The Delta silver is a specialty product found at art supply stores. Either works fine.
post #319 of 618
Is the application the same? For some reason I thought I read where one was easier to apply than the other.
post #320 of 618
shouldnt' be a difference. They're both a beeotch to apply if you're inexperienced with a sprayer. But once you finally get it right, the results are amazing.
post #321 of 618
Amazing?
Really?
post #322 of 618
CMRA how would you say the screen compares to commercial offerings? I'm ready to get my hands a little dirty.
I currently own both a gray wolf II and a high power, but I cannot justify another 600 bucks to 2.35 at 120 inches wide.
I am a little excited that you report gain in your screen.
post #323 of 618
I prefer mine.
I concur.
I estimate 1.5, never measured however.
post #324 of 618
I love what you did with the screen.
I have a Benq W10000 proj with a current 110" 16x9 Screen Goo CRT White screen - the colors are great- but it lacks pop.
Plus I wanted to go to 10' wide 2.35 screen.
Would you recommend the Silver?
Also is it as simple as mixing:
1/2 gallon Behr Faux Glaze
4 oz. Delta Ceramcoat Silver Metallic from Michael's Arts & Crafts
(Substituted for the darker Behr Silver Metallic)
20 oz. Filtered Water
and applying?
Can I use a roller instead of a sprayer (trying to keep cost down)?
Do I need to primer as I currently have Screen Goo white on the screen?
thanks,
Jon
post #325 of 618
No rolling.... spray only.
Your formula is correct, but should be distilled water.
can't comment on the Goo vs Primer.
post #326 of 618
and applying?
thanks,
Jon
Yep, spraying is NOT an option. You'll have to bite the bullet there.
Recommended. Kilz2 infact. This isn't to say something other may not work, just the primer is proven. You may opt for a Do-able board as MM did and still get excellent results.
Good spraying. CMRA
post #327 of 618
CMRA,
Would you mind editing the #1 post in this thread with the current formula to preemptively answer that two most common questions?
What is the correct proportion of ingredients and application technique?
Is spraying necessary?
These two questions are answered many times within this thread, and the original thread. I know the answers only through reading 100's and 100's of posts. If the original post contained the answers, more people would be inclined to try the technique.
post #328 of 618
Merry Christmas fellow screen painters! CMRA
post #329 of 618
I am looking for a light gray screen with about 1.4 gain. I have a Mit 4900 and would like to up the gain for a larger screen and improve blacks. I should have the projector next week and would appreciate some advice from someone with similar situation where they were looking to add some gain and to improve blacks, this will give me 14-16FL.
This is difficult reading for me, guess I am too tired and will try reading some more tomorrow. I understand the the recommended starting point is a neutral gray and adjust from there. However, reading about all the additives and adjustments confuses me. I believe you can continue to paint the screen by adding coats (metallic/polypaints) to the gray base achieve the desired results? Is that correct? Appreciate the confirmation that I am on the right track.
Starting point:
Kilz2
Behr~N8
Lamp Black 0 10 1
Brown Oxide 0 2 0
Medium Yellow 0 1 0
Then see what I looks like and possibly....add metallic paint polypaints... add gain and soften it... till it is just right. Is this the process?
post #330 of 618
I found Tiddler's video, this doesn't look too bad?!! Although I am planning to spray my screen, the video confirms the basic coating procedure of the different materials and the appearance when applied. Any suggestions on formulas to achieve the desired screen ? It looks like a gook Kills II base and Rust-oleum – High Heat “Silver” (spray paint) may be the ticket (as seen in Tryg's thread).
Also, I found a lightly used hvlp sprayer at Amazon for half price... we'll see how lightly used it is in a week.
Tiddler, give that baby a bottle!!!! You can hear a baby crying in the background. Thanks for your video!
Do you know why kids dislike it when Santa is no longer around? Because they prefer his presents!!
  Back to Forum: DIY Screen Section
