I made a couple of videos of the straining through the sock strainer and of me spraying. I don't know if its right or not to be honest. You'll want to turn the volume down a bit for the first video and yes, you have my permission to laugh frantically( as if you needed it, lol) in watching me trying to hold the camera with one hand, the gallon paint can with the other one and holding the paint cup with my feet. Once i saw it it made me laugh to, lol. Was hard getting a good view of the paint straining into the paint cup.
http://s591.photobucket.com/user/newdude19781/media/DSCF3960.mp4.html
http://s591.photobucket.com/user/newdude19781/media/DSCF3961.mp4.html
I'm concerned about the crater looking part in the paint pattern which you will see in the video. The pattern at 14 inches away is a little over 10 inches long so that meets the requirements. Here is a pic of a quick sweep over my plexiglass.
the paint doesn't gather well on the plexiglass it seemed to shrink into a bunch of dots. When doing S-I-L-V-E-R is the paint supposed to be a even thickness through the whole screen after making all your swipes from left to right using the paint gun. Like if you where trying to do a ligth fusion using Silver Fire and the whole layer has to be even and same thickness throughout?? I'm not familiar with this paint mixture and not sure how it's supposed to act but I'm not going any further until i get your opinion and approval. I'll make some more videos if you need.
But now I know you realize that spending for a extra New Gallon Can to strain the mix into would eliminate having to strain each and every Cupful. And should you need to restir after 2-3 hours, you can do so and just keep on pouring.
