AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › CMRA's S-I-L-V-E-R solution starts here:
CMRA's S-I-L-V-E-R solution starts here: - Page 23
post #661 of 733
Originally Posted by narhic_fd View Post
Between S-i-l-v-e-r and Silver Fire, which one does a better job maintaining whites while at the same time giving contrast enhancements??
S-I-L-V-E-R.....by a long nose.
post #662 of 733
MississippiMan, I want to think you very much for all the info you've given me. I just noticed that out of the 23 pages of this whole forum topic the last 4 PAGES eek.gifeek.gif have been mostly devoted to questions i have had. After all these questions, I should be able to fully help anyone else who ever decides to do a s-i-l-v-e-r and post questions on here, lol. biggrin.gif
post #663 of 733
Funny....I would have never noticed had you not brought it to my attention. wink.gif
post #664 of 733
MississippiMan, I know you haven't done a s-i-l-v-e-r with the graco gun, and I'm sure we talked about this but when it comes to s-i-l- v-e-r, it says for a gallon of s-i-l-v-e-r you start with 16 oz water. I'm also guessing that to do a quart you would start with 4 oz water. In the experience you've had with s-i-l-v-e-r how much distilled water, over the recommended 16 0z or 4 0z(if your doing a quart) do you find your self putting into the mix to give the best viscosity to spray?? Lets say you do a quart and put in 4 oz water, do you find that 4 oz of water is enough to give a good spray or do you usually add another 1 or 2 oz(for a quart) or 2-4 oz if you are doing a gallon?? It would help me to compare how much water I'm putting vs. how much you would put in. thank you smile.gifsmile.gifsmile.gif
Edited by narhic_fd - 9/19/13 at 10:10pm
post #665 of 733
I always add all the water needed at one time, into a full gallon...not per quart. This because the water / Glaze combo requires both to properly disperse the Silver Metallic into the medium. Also, you want every coat to posses the same consistency, and doing it in that manner assures such.
Even so, acquiring an eye for how the paint pours out into the Gun's Cup is needed.
Please note that after mixing Water / Glaze / Silver that you strain into a clean container for storage / dispersal. You do not strain each load into each Cupful. All you ever have to do after straining is remix the paint every 2 coats or so to evenly disperse the Silver into the mix...avoiding any possible separation.
I think a lot of your issues revolve around second guessing the viscosity because it's so difficult to judge how much paint is being applied with S-I-L-V-E-R. But you already know what happens when you put too much water into the mix. eek.gif
At very most, 4 additional oz a Gallon should be considered... and that ONLY because you can feel...or not feel as the case may warrant....that the paint does not seem to be flowing evenly out of the gun.
Also, to judge the height of your pattern, you have to shoot onto a practice sheet....holding the Gun in one place for 2 seconds do at to lay down a saturated footprint. Yeah...the paint will run like crazy pretty fast, but still, the visible wet spot will go much further to allow you to judge flow and delivery than trying to judge by looking at what goes down as you actually spray.
post #666 of 733
Okay im a little concerened. I thought is was okay to make a quart of s-i-l-v-e-r as long as the ratio is correct. For instance for one quart s-i-l-v-e-r I would mix 1 quart faux glaze with 2 oz liquitex silver and 4 oz water.your saying you have to make a gallon
post #667 of 733
Nope...I said "WHEN" I make a gallon I mix all the water in then. Of course if you make a Quart at a time, you'd add only the prescribed amount of water for said Quart.
I'm going to go take an Excedrin now..............................................
At least one thing is certain....you really help me measurably boost my Post Count. biggrin.gif
post #668 of 733
I'm glad i can be of service, lol. biggrin.gifbiggrin.gifbiggrin.gif Thanks for all your help dude.
Question...when you push the sock strainer into the graco paint gun container, how far down into the container do you push it??? 1 inch...inch an half, what?? yeah, I feel getting the right viscosity has been the thing that has scared me the most. I've realized how big getting the right or wrong viscosity can really mess things up. I went into the Silver Fire Thread and watched the videos on the straining and believe i have down better now.
post #669 of 733
The "Sock" is stretched tight across the opening, then depressed to form about 1.5" a deep concave reservoir. As the paint is straining...at the correct rate of addition, it should / will pool about halfway up the depression, then the the weight of the paint pool and gravity should equalize and the rate of "pass through" become steady.
post #670 of 733
Now, I know we talked about how fast to run the squirrel cage mixer while mixing but How long do you mix it with the squirrel cage mixer before you actually start testing the viscosity by pouring it through the sock strainer into the paint gun container?? This would apply to, maybe, you've just got home and before you spray you want to mix the s-i-l-v-e-r or you've already strained it and realized the viscosity isn't correct if you need to add some more water to it. How long would you mix it in each instance??.
post #671 of 733
About 1 minute at most. 30 seconds is usually all that is needed
post #672 of 733
Okay MississippiMan, I'm going to do some spraying of s-i-l-v-e-r since i have the mix already. I did what you told me when it comes to the straining. I pushed the sock strainer into the paint gun cup 1 and 1/2 inches deep(probably more like 1 3/4 inches though). I poured the s-i-l-v-e-r into the the strainer like you would pour a glass of milk and so on. Here's a video of the straining. Tell me what you think:
http://s591.photobucket.com/user/newdude19781/media/DSCF3997.mp4.html
Sorry about the loud Christmas music in the background. I can't believe my camera picked that up so well....And yes... I know it's weird to have Christmas music playing when it's not even October. biggrin.gif
Edited by narhic_fd - 9/28/13 at 8:28pm
post #673 of 733
That looks real good. I also checked out your "pattern" example.That looks good too, but from what I viewed, you should increase your spraying distance about 3"-4" out to 16" away from the surface. And "Dust" baby, Dust.
post #674 of 733
That spray pattern from the previous pic was the messed up, SUPER diluted version i did a while back and my normal formula is the right one. This s-i-l-v-e-r formula is temperamental. I did some test spraying with the viscosity on the video up top and i had to dial back the paint flow trigger because it was spitting. It wasn't spitting when it had a little less water of viscosity before that test up top. I'm going to let it sit out over night to take some of the water out and get it back to the viscosity before the video i posted up top. Now, I am using the 3900 turbine and i was wondering if the added pressure from the 3900 vs using the 2900 will make a diff in how this paint will flow out of my gun..Will it effect things??? Since the 3900 give more air does that mean my s-i-l-v-e-r doesn't have to be quite as diluted???
post #675 of 733
So, one night of letting the mixture sit out and it has a better viscosity this time. Paint doesn't flow through the sock strainer quite as much but it should spray good now. I'll give it a go morrow. Here's an updated video of the viscosity now. Sorry for the clarity of the video. I'm using my camera....I made sure to leave out the Christmas music this time, LOL
http://s591.photobucket.com/user/newdude19781/media/DSCF4001.mp4.html
post #676 of 733
Okay, MississippiMan. I've been watching the video's on the silver fire thread of you straining the paint into the paint gun cup and there is something I noticed on this video:
http://s586.photobucket.com/user/MississippiMaurice/media/Paint%20Draining-Filtering%20-Stirring%20videos/PaintDraining.mp4.html
I noticed that after you were done pouring how quickly it took the rest of the paint to spill out of the sock strainer and into the paint gun cup underneath. I then compared it to how long it took my paint to empty out the paint strainer into the cup underneath and noticed how MUCH slower my s-i-l-v-e-r was draining in the video's above. Should s-i-l-v-e-r be straining with the same frequency as silver fire. IF you wouldn't mind have a look at my video's and see what i'm talking about.
post #677 of 733
I did....and yes, it's a little slower than it should be. But not by much...and it does not take much additional water to make it so.
post #678 of 733
MississippiMan, early you said when it comes to viscosity of the mixes it was " The Lack there of". When it comes to the mixes and viscosity what do you mean?? once the mixes achieve the right viscosity do they have a high viscosity or a low viscosity once proper viscosity is reaches?? Are these mixes supposed to thick or thin when it comes to proper viscosity??
post #679 of 733
Viscosity refers to the degree of thickness. "High Viscosity" means "thick-er-er" biggrin.gif
C'mon...you already know that all the spray-able Mixes must be thin...not thick. confused.gif
post #680 of 733
yeah...,.I just wasn't sure about the deffintion of "Lack of viscosity" and made me think the paint mixer were thicker instead of thin. biggrin.gif
post #681 of 733
So, I did 7 coats on test piece and i must say that this is a very neutral grey. It reminds me a lot of the behr silver screen paint, meaning the neutrality of the grey. It wasn't a overpowering grey like Silver Fire. It did take on more of a silver color as the the paint dried in the last 2 days. The grey stuck out more once i put it up against a plain white like my TWH. It does give a little better darker colors and maintains the whites better then the behr or silver fire.
post #682 of 733
MississippiMan. If it's cool I'm going to give you a call morrow about my mix. Will be way easier to explain on phone then tons of post.
post #683 of 733
Sawright.......if I don't answer the first time....keep trying.
post #684 of 733
When it comes to S-I-L-V-E-R, i think what has confused me the most is the varying amounts of water people have used for their mixes. They follow as such:
Originally Posted by michaelscott73 View Post
So using the Double Duty with the following forumla and ratios I should be good to go:
1/2 gallon Behr Faux Glaze
4 oz. Delta Ceramcoat Silver Metallic from Michael's Arts & Crafts
(Substituted for the darker Behr Silver Metallic)
20 oz. Filtered Water
That one they made up half a gallon(little more once you factor in the 20 oz water) but used 20 oz water for just half gallon.
So I mixed 1/2 Gallon with what ended up being probably 28oz of water and 5oz of silver. I've finished maybe 10 coats with the gun fully open...maybe going a little faster than 3 ft./second on application. I still have 3/4 of a half gallon of mix left....guess that equates to about half of what I mixed up....50 oz.
The question is...do you think I am done?
That one they used 28 oz water for his half gallon mix.
Originally Posted by pb_maxxx View Post
the prescribed mix is 5% metallic and 95% glaze...
personally, my preference is...
32 oz glaze
24 oz water
8 oz delta silver.
mix thoroughly. did i say thoroughly?!
7-8 dusters.
yes. better blacks than a white screen.
no i can't give out MM's password. also the wagner vid shows MM doing full coats... not dusters.
that one where he used 24 oz water for just one quart of s-i-l-v-e-r( yes i know the formula equals over 64 oz, I just call it what the size of the Behr Faux glaze is)
Then there is of course the formula you gave me when i asked it few pages back:
1 Gallon Behr Faux Glaze
8 Oz Liquitex Basics Silver Metallic (Jar preferred)
http://www.amazon.com/Liquitex-Basics-Acrylics-Colors-silver/dp/B002643NXY
16 oz distilled water (to start)
Mix into 2 gallon Bucket w/Lid
Use the Squirrel Cage Mixer (best price... and Free "A-Prime" delivery)
http://www.amazon.com/Homax-69011-1-Gallon-PolyPro-Galvanized/dp/B000ELORFE
After mixing and straining, a test using the Gun determines how much if any more water is required. Also, the size Needle Tip. Using a 2.0 Tip that comes with the Graco, you must absolutely practice quick, rapid Dusters from a specific distance. With a 1.5 mm tip, things are a bit more refined. Dusters are still the order at hand, but the method of applying becomes less frenetic.
Do you have this?
http://www.amazon.com/Factory-Reconditioned-Graco-HV2900-Paint-Station/dp/B005QQ0AFS/ref=pd_cart_recs3
Then take my very best advice and get this accessory 1.5 mm Needle Kit
http://www.amazon.com/gp/product/B004BG6DIM/ref=ox_sc_sfl_title_8?ie=UTF8&psc=1&smid=A2NWLOWWF5G7JX
When most of these guys were making up some s-i-l-v-e-r they were usually using way more water then 16 oz. That was confusing me. I was reading some of those post and thinking if that one dude used 20 oz water with 1/2 Behr Faux glaze, and 4oz silver then since I'm doing a gallon plus of s-i-l-v-e-r i should probably use 40 oz of water.
Also, if you remember i asked you that " if you were making a gallon plus mix of s-i-l-v-e-r you said "You would use 1 gallon of faux glaze, 8 oz silver and no more then 4 oz extra of water equalling 20 oz water total for the completed mix" so that would be
1 gallon Behr Faux glaze
8 oz silver
and 20 oz of total water.
So, why the varying degrees of water to glaze/silver ratio???
post #685 of 733
silver in traditional form... is as MM has the ingredients.
the water.. as posted is a minimum based upon the more powerful sprayers such as the wagner double duty... which has head unit/needle that exeeds 2mm.
we stress getting the right viscosity for your sprayer and that means experimenting to find out how to get plume for your sprayer without spitting, etc. the smaller the needle, or less power your unit has... the more water you'll need to add to your mix.
never fear... the water evaporates... so in the end it doesn't matter... except for how many coats may be required to get the coverage necessary to evenly distribute the mica and have them in a density that allows silver to excel at what it does.
as for MY personal silver mix... it was not meant to confuse. i'm simply attacking the silver/mica density more quickly and wanting to do it with less coats. but i've been spraying for quite some time now... and i would not expect you/others to achieve the same results.
post #686 of 733
okay, cool... that helps clear things up. Since i am using the Graco Spraystation 3900 that is why mississippiman gave the formula that he did. glad to get that cleared up.
post #687 of 733
Okay, so I made up a small batch of s-i-l-v-e-r using 1 qt Behr Faux glaze, 2 oz silver and 4 oz of water. Since a gallon plus of s-i-l-v-e-r would require 16 oz water and i was making a 1/4 of that i used 4 oz water. I then added 1 tbs of more water to thin out bit more. I'm guessing if you add water in 2 oz spurts for a gallon plus of the this stuff then take 2 oz and divide it by 4 which is 1/2 oz which equals 1 tbs. Did some test spray and was getting some good size spiting coming out of it so i added 1 more tbs water. That seemed to stop the spitting and was getting a better feeling of the paint exiting the gun.
Next concern was the spray patteren size. At about 14 inches from the substrate is was producing a 7- 8 inch long spray pattern. I had to let the trigger stayed engaged for about 2 or 3 seconds before i could see the pattern. So, do you think i should add 1 more tbs water???
post #688 of 733
yes. it should make your spray a little more fine. and also back out to about 16".
post #689 of 733
How does this look speed wise for spraying. The gun and turbine isn't on and I'm not worried about the overlap either, just wanted to make sure the speed wasn't to fast or slow. Thanks guys.
http://s591.photobucket.com/user/newdude19781/media/DSCF4018.mp4.html
post #690 of 733
Well, Did a test spray and the pattern was beautiful! I did forget to do one little, big, thing though. I forgot to make that first coat a really quick, light duster, since i was spraying onto the thrifty White Hardwood with its glossy surface, and the paint receded and gathered together into a bunch of drops. Should have remembered that. I wiped it down and will start over tomorrow. rolleyes.gifrolleyes.gifrolleyes.gif
  Back to Forum: DIY Screen Section
