First, I said:
Originally Posted by
cynical2 (that's me)
CMRA, what do you mean "For duster coats only"? Aren't all 7 coats duster coats?
To which you, MM, replied:
MississippiMan
CMRA was only repeating the obvious....that the S-I-L-V-E-R formula is for "Duster Coats" only
Usually when one starts a sentence starts with a form of address (as I did by specifically addressing CMRA), that means that they are asking that specific person a question. Based on reading numerous posts from CMRA, I'm 100% confident that he doesn't need you to speak for him. While I appreciate the input from anyone that is willing to offer it, my preference is to hear it straight from the man who invented the formula. Other people may believe that they have their facts right, and be 100% confident in their own ability to answer a question addressed to someone else, but they may be mistaken. For an example of what I mean, see below.
Also, the 100% SM coat that used to be sandwiched between kilz-2 has been dropped from the formulation now, right?
To which you replied:
MississippiMan
Wherever did that come from? Had to be from someone else's misinterpretation because neither I nor CMRA have ever advocated such a step.
Here is the example (mentioned above) of someone being sure that they know the answer to a question, when in fact they don't (again, this is why I directly posed my questions to the inventor of the formula). Back when silver started it was a rolled application (spraying was optional), and a piece of the instructions stated:
CMRA
After electing your substrate, roll it with a minimum of
two coats Kilz 2 latex primer. Allow to dry between coats.
Next, roll a coat of 100% silver metallic over the primer.
You'll need to work this in. This is the reflective base
coat that gives 'silver' its punch. Completely let dry.
Next, roll two 'light coats' of kilz 2 primer over the SM.
MississippiMan
Are you interested in this doing this application, or merely asking questions?
Your use of the word "merely" gives me pause. I'm not sure if it was intended to be as condescending as it came across, so I'll give you the benefit of the doubt and assume that you just don't understand how you come across when you post something like this. Currently, I'm seeking to understand the formula and it's application. I may apply it at some point in the not-so-distant future...or I may not. I just put Kilz2 on my wall today, will assess the image, and will proceed down the simplest, least expensive path
that I believe will create an image that will knock the socks off of anyone that steps into my HT. Part of making a well informed decision is to research the options that exist, and then to base one's decision on the data gathered during the process of conducting that research. And, the act of gathering said data often involves "merely asking questions."
