AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Question about "pre out" amp connection.
post #1 of 6
I have a TEAC A-1D integrated amp. On the back is a connection marked "pre out". A couple of questions about this, please.
1. Can I hook up a pair of powered PC speakers from this connection?
2. If I can, will connecting to the pre out somehow automatically turn off the power amp portion or does it keep running?
post #2 of 6
1. Probably.
2. Probably not. It is likely to leave the amps functioning.
Is there a user's manual to hand? Is there only one pre-out or is there a pair?
post #3 of 6
Being an electro-dummy I might not answer your question correctly, so here is a pic of the output.
http://www.polkaudio.com/forums/atta...6&d=1151982347
I do not actually have the amp yet. I just ordered it from the TEAC factory authorized refurbisher. They claim it will arrive "like new with all original documentation".
Is it possible that if I set the "power switch" to off and the "standby" switch to on it might have enough trickle charge for the preamp to work?
post #4 of 6
It just appears to be a normal pre-out for your left/right channel if your going to use an external amp and bypass the internal amp, nothing out of the ordinary. Most receivers have this option.
post #5 of 6
No, when you turn the "power switch" off, it prevents current from flowing through the circuit...it means it's off.
post #6 of 6
Yes. But he wants to know if using these outputs will turn off the internal amps and that is doubtful.
