AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Denon AVR-3808CI Thread
The "Official" Denon AVR-3808CI Thread - Page 55
post #1621 of 19878
Originally Posted by fafner View Post
I don't have "older" HD-DVD or Blu-Ray players (why would you assume that?) I have the Toshiba A35 and the Sony 301 (with upgraded firmware. Would you please go on with your explanation please?
- Unless a fellow owner comes into this very thread and explains how those players need to be set up, you're going to need to do a little investigative work on your own. Go into the audio settings for each player. Under HDMI, there should be a setting for Bitstream. If you have it set for PCM right now, you'll have to change it.
No need to get defensive, my original comment was tongue in cheek. Hence the smiley. Having your player decode TrueHD to PCM is no different than having your player doing it. As my previous link noted, you're actually losing sound quality for advanced features. Sanjay has one of the best explanations that I've seen.
http://www.highdefdigest.com/news/sh..._Necessary/853
Think of Dolby TrueHD and DTS-HD MA as zipping a computer file to save space. None of the data is discarded, just packed more efficiently to take up less storage space. When you unzip the file, 100% of the data is still there, and you get a bit-for-bit copy of the original.
If you had a zipped document that you wanted to send me on disc, you would have two choices. You could unzip it on your computer before putting it on the disc. Or you could send it to me as a zipped file (would take up less space on the disc) and I could unzip it on my computer. Either way, I end up with the exact same document, down to the last letter.
post #1622 of 19878
It seems obvious that since the Denon 3808 has a True HD light on the display panel the light should show up when receiving/sending True HD signals.
Otherwise, people like me and the others you are obsessing over will rightfully think that something wrong is going on.
- If your player is doing the decoding, you're going to see Multi-Channel PCM light up on the 3808. If the receiver is receiving Dolby TrueHD as bitstream, then you'll see the display on the receiver light up. Either way, you're getting the same exact sound quality.
post #1623 of 19878
fafner
I'm sorry I made an assumption but you never indicated you had a player capable of outputting in bitstream and that you understood that issue. I presume then that you know to have the players output audio via the HDMI via bitstream? If you do, it sounds like your denon is broken.
post #1624 of 19878
Actually, I already asked a fellow owner in my original post.
FYI, there is no Bitstream option under HDMI for either player. The A35 has Bitstream for SPDIF but I am not using that.
I know you are trying to be helpful but telling me and others to do things that are not possible is not helpful at all.
Also, please note that I did not ask whether the sound would be the same whether decoded in the player or the receiver. I purposedly did not want to go there.
I don't believe there is one post in this thread where a user has reported that the TrueHD icon lights up while there are many such reports in the Onkyo AVR threads.
This discrepency has led me to question whether the Denon has some fault in it that is preventing the TrueHD display. Perhaps I should have mentioned this in my original post or in a subsequent one.
Thanks anyway.
fafner
post #1625 of 19878
See above post. Neither of my players has an option for bitstream under HDMI. The choices are Auto or LPCM.
I realize that you also are trying to be helpful, but as I said above telling me to select something that does not exist is not helpful at all.
fafner
post #1626 of 19878
- I would try to contact this user or someone in this thread to see what they have their A35 set to.
http://www.avsforum.com/avs-vb/showthread.php?t=915405
post #1627 of 19878
"I have the Toshiba A35"....when did you replace your Toshiba A30?
According to this post just two weeks ago you purchased the Toshiba A30:
http://www.avsforum.com/avs-vb/showp...&postcount=263
NOTE: The A30 does NOT do bitstream while the A35 does.
Perhaps this is the problem you are experiencing!
Toshiba A35:
The HD-A35 offers 5.1 channel analog output and High Bit Rate Audio (up to 7.1 channel) via HDMITM. With content encoded in 7.1ch, this advanced surround sound is achieved through the HDMI connection bypassing the player´s internal audio processor and sending the signal to a 7.1 capable A/V receiver. High Bit Rate Audio will allow the consumer to integrate the HD-A35 with the latest multi-channel A/V receivers and enjoy a whole new dimension of high defi nition home entertainment. For improved contrast and detail, and smoother transitions, the HD-A35 also adds support for Deep Color via HDMI allowing compatible display devices to deliver outstanding video quality displaying up to a billion possible colors.
However, the Toshiba A30 does not offer this capability! :
THE HD-A30 TAKES THE PERFORMANCE AND CONVENIENCE OF HD DVD TO THE NEXT LEVEL.For the highest level of picture quality with today´s best performing high defi nition TVs, the HD-A30 adds 1080p output. That´s twice the resolution of a 720p signal. The HD-A30 is equipped with CE-Link HDMI-CEC connectivity. This convenient feature offers the capability to communicate with and control another HDMI-CEC compatible device in a completely new way. 1080p/24 frames per second (24p) support offers a smoother, more fi lm-like, viewing experience. Traditionally, movie fi lms are captured at 24 frames per second. The HD-A30 HD DVD player maintains this frame rate, allowing consumers to enjoy movies in their native frame rate.
post #1628 of 19878
I'm not sure what your obsession is with people wanting to know if their unit is working right or not.
Please provide an answer if you have one, and for your own sake, please stop obsessing over people who payed over a grand just wanting to insure that they are getting their money's worth.
fafner
Unless you have an HD-DVD or BluRay player capable of sending TrueHD via bitstream to your Denon, then the Denon will always say "multi channel in." Since the only players that can do that either have just come out or are not out yet, you likely don't have one so your player will (likely) never be able to output in a way that will cause the Denon to recognize the format as TrueHD. That is because by the time it gets to the Denon the player has already decoded the TrueHD bitstream into LPCM. Since any format can be sent over LPCM, the Denon has no idea what the original format was so it just says "multi channel in."
This is not a malfunction on the Denon. It is also not a malfunction of your HD-DVD or BR player.
With that being said, even when players become available that can send TrueHD bitstream, it will likely be meaningless anyway since the ways in which the discs are being authored REQUIRES that the decoding be done in the player and thus the output will ALWAYS be LPCM and your Denon will still not light up.
Read up on the HDMI 1.3 marketing scam.
If you bought your Denon just for TrueHD and the other new format, you should return it.
HTH.
Edit: just now saw you have the A35. Disregard first paragraph.
post #1629 of 19878
Toshiba A35:
The HD-A35 offers 5.1 channel analog output and High Bit Rate Audio (up to 7.1 channel) via HDMITM. With content encoded in 7.1ch, this advanced surround sound is achieved through the HDMI connection bypassing the player´s internal audio processor and sending the signal to a 7.1 capable A/V receiver. High Bit Rate Audio will allow the consumer to integrate the HD-A35 with the latest multi-channel A/V receivers and enjoy a whole new dimension of high defi nition home entertainment. For improved contrast and detail, and smoother transitions, the HD-A35 also adds support for Deep Color via HDMI allowing compatible display devices to deliver outstanding video quality — displaying up to a billion possible colors.
THE HD-A30 TAKES THE PERFORMANCE AND CONVENIENCE OF HD DVD TO THE NEXT LEVEL.For the highest level of picture quality with today´s best performing high defi nition TVs, the HD-A30 adds 1080p output. That´s twice the resolution of a 720p signal. The HD-A30 is equipped with CE-Link HDMI™-CEC connectivity. This convenient feature offers the capability to communicate with and control another HDMI-CEC compatible device in a completely new way. 1080p/24 frames per second (24p) support offers a smoother, more fi lm-like, viewing experience. Traditionally, movie fi lms are captured at 24 frames per second. The HD-A30 HD DVD player maintains this frame rate, allowing consumers to enjoy movies in their native frame rate.
Oops. Yes I currently have the A30 but am considering upgrading to an A35. Also I was wrong in thinking that the Sony 301 outputs HBR audi. I apologize profusely to everyone in the thread.
fafner
post #1630 of 19878
HTH.
Thanks. I do not have the A35 but have the A30. Sorry about that.
However,.....lots of people are seeing the TrueHD icon on their new Onkyo AVR displays. And yet I haven't seen one report of this happening on the new Denon models.
I really am just trying to understand why Denon apparently has the capability to display a TrueHD display icon when what you and others have been saying recently is that the decoding must done in the player and thus the TrueHD light will never come on. And why does the Onkyo display the icon?
Others have said that it doesn't matter whether the decoding is done in the player or the AVR, ie, the sound will be the same, but that is an entirely different issue that I am not interested in.
I am not concerned about the light, per se, but why it lights up on the Onkyo AVR's and apparently doesn't in the new Denons. Could you please address the issue from this standpoint?
fafner
post #1631 of 19878
Sorry this is rubbish.
post #1632 of 19878
Thanks anyway.
fafner
Check this post:
http://www.avsforum.com/avs-vb/showt...7#post11684457
Originally Posted by pclausen View Post
Here are a couple of shots playing material through my Samsung 1400:
X3: The last Stand:
5th Element:
post #1633 of 19878
Erik,
Thanks very much. Clearly I missed that.
fafner
post #1634 of 19878
Hi. Just got my 3808 and have a few questions to more experienced users..
1) I connected my PVR (Motorola DCT6416 - Shaw Canada) using the HDMI cable to the receiver. All seems fine. On the HD channels, the receiver indicates that the audio signal is 5:1 dolby digital. However, the salesperson at the store indicated that I would have to also connect the digital audio cable up because the PVR only dumps 2 channel audio over the HDMI link. But it does seem to be outputting 5:1 with only the HDMI cable. Can anyone confirm this?
2) Also. If I indeed did want to use the digital coax cable for audio, how do you manually assign this? ie. Tell the amp to pick the video off the HDMI and the audio off the digital coax. I don't really see a way to do that. Does the amp just pick the best available signal? Cause for my oppo DVD player it does indeed find the audio coming in on the dolby digital cable because the HDMI is via DVI with no audio.
3) There seems to be something odd with the volume levels. When watching TV from the PVR (HDMI connection from PVR to AMP), the volume seems low. I need to get it up to -20 db to get some decent volume out of it. But if I'm listening to CD (2 channel analog inputs), the volume is MUCH louder at -20 db volume setting. Anyway. Can anyone comment on that? I don't see anything on the PVR menus to adjust it.
4) What about 3808 firmware versions. I never saw a screen to dump the current f/w version. There are clearly some bugs that perhaps are addessed. Are there any release notes for newer f/w versions?
5) Minor. When I MUTE the main zone, it seems that the OSD is disabled. Thats stupid. I would still like the OSD to function for zone 2. Cause eventually I'm gonna broadcast the monitor out to all my TV's in the house on channel 117. That way I can adjust the AMP from anywhere in the house and use the TV to do it. Anyhow. I assume this is a "feature"???
Thanks in advance.
post #1635 of 19878
"2) Also. If I indeed did want to use the digital coax cable for audio, how do you manually assign this? ie. Tell the amp to pick the video off the HDMI and the audio off the digital coax. I don't really see a way to do that. "
Actually that is easy to do and I do it for my computer. Just assign the proper HDMI port to your component and then under audio select the appropriate optical port. The 3808 knows to use the video from HDMI and audio from optical with those settings.
fafner
post #1636 of 19878
http://www.avsforum.com/avs-vb/showt...&&#post9353634
Originally Posted by sdurani View Post
With HD DVD, soundtracks can be authored in the 'Advanced' mode, which allows multiple content streams to be live-mixed (mixed in real time). You don't need another soundtrack for foreign languages. Just swap out the English centre channel stream with one of the foreign centre channel streams. You don't need another soundtrack for commentary. Just reduce the level of the main soundtrack and mix in the commentary stream. Same with button sounds and other interactive features, like picture-in-picture.
Just like editing the document requires unzipping the file first, doing any of this live-mixing to the soundtrack requires decoding it to linear PCM first. This is why it has to be done in the player. They're not going to transmit every option to your receiver, just one soundtrack. You choose what you want to hear, it is mixed in the player (i.e, the soundtrack you want to hear is literally built in real time inside the player) and transmitted as a final mix to your receiver.
Current HDMI allows 8 channels of 96/24 PCM to be transmitted (more than enough resolution for any soundtrack), but not the new codecs in their native form. When HDMI 1.3 arrives, it will allow the new codecs mentioned above to be transmitted in their native bitstream, but only if they were authored in 'Basic' mode (no interactivity). If the soundtrack was authored in Advanced mode, then it cannot be transmitted in undecoded form; decoding in the player is mandatory because of live mixing.
So far, all HD DVD soundtrack have been authored in Advanced mode. Which means nothing will change when new receivers arrive on the market. Despite having HDMI 1.3 transmission and decoders built into the receiver, decoding will still have to take place in the player.
Further info on the HDMI 1.3 marketing scam:
post #1637 of 19878
HDMI carries digital and along with it you will get the respective digital codecs showing up properly...no need to do anything else here.
There are SRC Level adjustments in each Source. Check the menu under each source for "Other". see pic below....
You can check your FW versions in this manner:
http://www.avsforum.com/avs-vb/showp...&postcount=324
post #1638 of 19878
If you visit the Onkyo 905 thread JoeRod has been doing some testing with his new Toshiba A35 sending bitstream to his receiver and it is playing everything fine. He and a couple of others said it sounds better too letting the receiver to the decoding. I am not sure if "advance authoring" only has to do with "extras" or not but, since I don't care about extras at all I will soon be sending everythig to my Denon via bitstream and let it do the decoding.
post #1639 of 19878
Cool. Let us know if it works. Nothing beats real world experience.
post #1640 of 19878
Thanks guys....I'll check out the source level control. Not sure how I missed that....
Also. How did you know the sequence for dumping the f/w version???? Are there some docs I don't know about??
post #1641 of 19878
Main ver F/W is 1.03, sub ver 00.21, DSP1 36.45, DSP2 39.36, etc...I'll check back a few pages to see what the latest is. I'll probably wait a few weeks till they iron out the f/w updates a bit. Don't need a door stop yet.
Also. The source input level worked great (had to add +8db to get it close to the other input levels). I thought those menu items were read only...But really those are all the ones I missed for controlling the input/outputs....But I've only had the amp running for a day now so I guess I'll give myself a break...
Thanks again...
post #1642 of 19878
"2) Actually that is easy to do and I do it for my computer. Just assign the proper HDMI port to your component and then under audio select the appropriate optical port. The 3808 knows to use the video from HDMI and audio from optical with those settings.
fafner
Will this also work having a component video source (PS3 video set to component) with a hdmi audio source (PS3 audio set to HDMI)? This because I'm using a component cable to my 720p beamer and want to enjoy Multi-Channel PCM sound through the receiver.
post #1643 of 19878
But we have already been told by Toshiba that bitstream ignores advanced mode.
post #1644 of 19878
Thanks Erik
I appreciate your candid reply.
post #1645 of 19878
I don't know. That is one you have to try yourself.
fafner
post #1646 of 19878
I Noticed earlier in this tread there were some mentions of poor bass when not using a sub on the 3808, Having just purchased a 3808 a week ago initially I was very happy with the sound however yesterday I connected my front 2 Kef floor standers to the 3808 instead on my old SONY TA-F940QS HiFi amp and have to say I’m most disappointed in the resulting sound. Basically there is just no deep bass from the front 2 channels despite the speakers being set as Large and sub being turned off. Reconnecting the SONY amp to the front pre outs of the denon resolves this problem but im shocked that a £299 8 year old amp can show this £1300 Megga Beast a clean set of heals. It is clear to me that this is not a Processing/Preamp issue and is directly related to the front channel power amps having to high a low frequency cut off point. If anyone could source a schematic diagram for me I would be game to open the Beast up and mod it, then share the resulting details on the forum . Yes I know its under warranty but having worked in the electronics trade for 30 odd years this just dont scare me anymore.
Chris
post #1647 of 19878
Originally Posted by Digitalfreakus View Post
I Noticed earlier in this tread there were some mentions of poor bass when not using a sub on the 3808, Having just purchased a 3808 a week ago initially I was very happy with the sound however yesterday I connected my front 2 Kef floor standers to the 3808 instead on my old SONY TA-F940QS HiFi amp and have to say I'm most disappointed in the resulting sound. Basically there is just no deep bass from the front 2 channels despite the speakers being set as Large and sub being turned off. Reconnecting the SONY amp to the front pre outs of the denon resolves this problem but im shocked that a £299 8 year old amp can show this £1300 Megga Beast a clean set of heals. It is clear to me that this is not a Processing/Preamp issue and is directly related to the front channel power amps having to high a low frequency cut off point. If anyone could source a schematic diagram for me I would be game to open the Beast up and mod it, then share the resulting details on the forum . Yes I know its under warranty but having worked in the electronics trade for 30 odd years this just dont scare me anymore.
Chris
Did you check the crossover frequency, that might be set too high for your Kefs.
post #1648 of 19878
Thanks for the suggestion. Crossover is set to 40hz. this is as low as it will go. the point is I have no sub, dont need a sub, and dont want the hassle of a sub and all its associated problems. These Kef Q55.2 floor standers can shake the room when driven properly and do so very well in a 3808 > SONY QS > Kef setup. alas 3808 > Kef is a pretty weak second best .
post #1649 of 19878
Do you mean to say that you cannot remove the LF cutoff from the main speakers? I for one would really not like to see the low frequencies removed from my B&W 801s...
post #1650 of 19878
I dont believe that there is an intensional low cut off in place as the front pre outs are fine and sound awesome when pumped into an external amp on the same speakers. also the denon is configured for NO sub. there is no option in the crossover section other than the various frequencies of which 40hz is the lowest. if there are any Denon Representatives here id love to hear there take on this.
