AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Denon AVR-3808CI Thread
The "Official" Denon AVR-3808CI Thread - Page 643
post #19261 of 20190
If you haven't had the Dyn EQ/VOl upgrade installed, you could try starting the macro with the PARA/SEARCH button.
I don't have that installed.....but if I did, how would it change your answer or would it change your answer?
post #19262 of 20190
After the upgrade, the PARA button becomes a Dyn EQ/Dyn Vol button (ie. doesn't take you into the menu).
post #19263 of 20190
I hit the search button on the Denon remote and on the Harmony Remote (which knows the Denon is a 3808) and yet I don't get anything to happen. I mean, it isn't that hard....what the heck am I doing wrong? Does the search button only work in certain menus?
Thanks for your help.
Stephen
post #19264 of 20190
Search works when playing music from attached storeage or streamed. Do't think it works anywhere else.
blairy
post #19265 of 20190
I'm running my Oppo BDP 95 into my AVR 3808CI using the Denon's Ext. In analog inputs. My question is whether changing the Manual EQ settings in the Denon to suit my acoustic preferences will have any effect? Or, are all such controls disabled and only functional when the connection to the Denon is made digitally or with DSP engaged?
post #19266 of 20190
No processing of any kind on multich analog inputs. It never gets digitized.
post #19267 of 20190
So, then, if I want to keep the signal from my Oppo's DACs both analog and pure, I can't make any individual frequency adjustments on the Denon and would have to rely on changing distances and dB levels on the Oppo?
post #19268 of 20190
yes...
the "purity" of the signal, fwiw, is destroyed as soon as it hits your loudspeakers...
post #19269 of 20190
...and then your room.
post #19270 of 20190
yup...
post #19271 of 20190
Originally Posted by sittodorov View Post
Hello fellows I have the following problem. I use my PC like a Music server. It is wired to my d-link router and from there to my Denon 3808. I use my Denon 3808 network capabilities to access my entire music library. My library is organized as follows folders of bands/albums/mp3 320 kbps songs. My PC runs Winows XP Service pack 3 and Media player 11 as it was required from Denon.
It happens some of the songs I am trying to play to block the receiver. On the display shows name of the song + 0:00 like minutes and seconds and I can't move from there even if I switch to a different input source or trying to go back in the menus or even switching off the receiver. The only one thing to works is to change the way receiver gets IP address from DHCP on to off or opposite and then I can access net/ usb feature as normal.
I do reset the microprocessor and have one of the latest firmware versions. Always have the same problem with certain albums. Help will be much appreciated resolving this irritating issue.
Thanks in advance.
Hello fellows,
I would like to share resolved problem of Denon 3808 blocking after attempt to play a certain albums and songs from my relatively large music library, which was organized by WMP11 (officially Denon recommended) with same size artwork and same files format. My big thanks to CalgaryCowboy, who gave me the idea to switch to Media monkey and remove the artwork from the files.
Still I needed some times to set the MM right. It has great tag editing features and also hooks DLNA service flawlessly.
First when adding the library to MM, you have to go to tools\\options\\library and unchecked scan file directory for artwork. This will save your time to manually delete all the artwork located in the album folders which is actually hidden (to see hidden files for windows XP SP3- in windows explorer have to go to tools/folders option and then change to show hidden folder and after hit the apply button you can see the art work files WMP created and actually the reason for all the mess).
After that you can transfer files into your MM. After the transfer you still have the artwork for every single song embedded in the tag I guess. You can easily remove that by hitting the right button over the picture and after choosing remove image to check the option remove image from all the tracks in the album. So there you go, no more image to give you trouble (even it stays in the original album folder as hidden artwork- no worry about this).
There is a tricky part in useful option otherwise. Under tab tools locate /auto-organize files. You have to be careful to choose from different strings of renaming the files and saving options (first time I ended with songs listed alphabetically in the album instead by original order).
I am still working on the issue because of the size of my library, but for now every single album and song plays perfect.
Hope this will help somebody with similar issues.
Cheers!
post #19272 of 20190
i know i'm beating a dead horse but i really feel like this thing should do 3d. ps3 detects the 3d monitor when connected through the 3808 and it even displays a garbled image, as if it's outputting a pal signal. If the 1.3 ps3 can do 3d why can't these 1.3 receivers be updated? I'm ok with 720p 3d just not with the choice of spending 300$ on a dedicated 3d bluray player or another $2xxx to get the AVR-4311.
post #19273 of 20190
I just broke down and bought a Panasonic 310 BD player that has dual HDMI outputs and ran one to the 3808 and the other to my display.
post #19274 of 20190
The PS3 has a much more highly sophisticated processor on board and is able to do the processing via software. You can get a used dual HDMI 1.4 Panasonic BD310 from Amazon for < $150. Also note the PS3 still cannot play DD TrueHD with 3D video as can the BD310. Although, connecting the PS3 HDMI to the 3D display with optical to the AVR you will still get the higher bitrate DD/DTS tracks on BDs which for the vast majority will be indistinguishable from the HD audio track over HDMI.
http://www.amazon.com/gp/offer-listi...condition=used
post #19275 of 20190
"I just broke down and bought a Panasonic 310 BD player that has dual HDMI outputs and ran one to the 3808 and the other to my display."
Did this some time ago with the 310. Very happy with the configuration.
post #19276 of 20190
how much processing power does it take to simply pass the signal through?? It has to be a software/firmware issue. i feel like they integrate so many redundant features into every device these days driving up the cost but skip the basic "courtesy" features. maybe one day we will be able trade in the netflix/streaming ability of the 99/100 devices in our setups for the ability to pass through a signal untouched.
post #19277 of 20190
it's a chipset change for almost every piece of equipment...
the reason the ps3 is able to do it (as noted) is that it has processing power up the wazoo, and can emulate a 1.4 stream via a 1.3 chipset... and it takes almost all of that processing power to do it...
post #19278 of 20190
^so why are other 1.3 receivers as well as splitters/switches with considerably less hp than the ps3(and probably less than the 3808) able to pass through the 3d signal? additionally why hasn't someone just created something to do what the Panasonic310 does internally? I already have a 3d capable bluray player (ps3)give me a simple device that does 1.4 in and 1)1.4 video out & 2)1.3 hd audio out.
post #19279 of 20190
You can keep complaining about it or you can deal with it. But it is what it is man.
post #19280 of 20190
What I don't understand is people expecting equipment to support something that wasn't even available at the time. I wish everything was upgradable for forever, but with the technology changing every few months, it is what it is!
post #19281 of 20190
=FACT
but complaining about it makes me so much better...
there's a difference in expecting things to last forever and expecting to not have to replace your entire home theater for something that it's already capable of.
post #19282 of 20190
First off, you are the one claiming it is capable.
Second, you don't have to do anything. Nobody is forcing you to need the latest gimmick with 3D support. News flash: if you want to have the latest tech in the consumer electronics space, you are going to need to update your gear frequently. Deal.
post #19283 of 20190
I don't know if stopdrpnro is complaining as much as he would like to know the technical limitation that stops the passing of 3D through the Denon.
I understand his "knowledge quest" so to speak, but also understand the frustration of members here over the multiple posts.....we don't have the answer.
I think the Denon is always somehow processing the signal, which strips or corrupts the 3D signal beyond use.
Many players have dual HDMI outputs, and modern activity based remotes can handle the complex switching of inputs/outputs of multiple components that in the past made the single connection between monitor and AVR a "holy grail".
post #19284 of 20190
Do the "2-Channel Direct/Stereo" settings in the 3808 have any effect when using the Ext. In multichannel inputs?
post #19285 of 20190
Originally Posted by s2silber View Post
Do the "2-Channel Direct/Stereo" settings in the 3808 have any effect when using it's Ext. In multichannel inputs?
No. EXT IN bypasses ALL processing.
post #19286 of 20190
Thanks, although you can boost the subwoofer output for the Ext. In inputs, can't you? And, if so, what is the ideal boost between the source -- say the Oppo BDP '95 -- and the setting on the Denon? Right now, I've got the Oppo set for the maximum 10dB boost and the 3808 set to +5db. To my ears, that sounds pretty good, although maybe a bit too much. What's your advice, or that of anyone who's also using the same model Oppo with the '3808, on that mix?
post #19287 of 20190
If you have an Oppo why aren't you using hdmi? Then you can have digital processing and accurate bass management for sure. The 3808 can receive all hi rez audio including SACD over hdmi.
The correct analog LFE boost can be tricky especially with multich audio, which may not have been mastered at film standard. You may want to ask in the Oppo forum.
post #19288 of 20190
I know, and I do use HDMI for movies most of the time. However, when it comes to music I prefer to use the Oppo's analog outputs into the Denon's Ext. In inputs to take advantage of the Oppo's superior DAC's and to prevent any override or duplication of its sound processing.
post #19289 of 20190
I forgot about that and have had the Oppo BDP-93 for three months now and haven't tried that yet. I don't listen to a lot of music in my HT as I have a dedicated music system in another room. Ah something to mess with this afternoon.
post #19290 of 20190
I did many HDMI/analog comparisons with Oppo players (83, 83SE, 93) and Denon AVRs (2809, 4310) over the past couple years. With the vaunted Oppo83SE's dedicated stereo analog DACs into Ext In, my untreated room's bass boom wrecked overall SQ. I then moved the ICs to a regular analog input on the AVR and redigitized the signal to apply Audyssey. That yielded slightly better SQ than going straight HDMI from Oppo to Denon. Once I got the A100 (4311) I could no longer hear any advantage to the Oppo analog at all, whether MultEQXT32 was applied or not. I later switched to a DenonLink player which is a distinct step up in SQ for CD, SACD, DVDA.
