Please use this Thread for all discussion on the Denon 3808CI
Below are the details provided on ListenUp.com....
Discription:
Dolby TrueHD, dts-HD Master Audio, and 1080p video
The Denon AVR-3808CI A/V receiver serves as the brains and brawn of your high-definition home theater.
* HDMI 1.3 compatibility, which allows for 1080p signal transfer and decoding of the advanced audio formats used in Blu-ray and HD DVD players
* Analog to HDMI video upconversion, so all your video sources look as good as possible
* 1080p scaling is done with high-performance Faroudja DCDi chip
* XM Radio ready
* PC/Network connectivity provides the option for automatic firmware updates
* Audyssey MultEQ XT audio set-up tailors the receiver for your room's specific acoustics
The AVR-3808CI continues Denon's new tradition of stellar CI-designated products, as it's chock full of the performance and features you require for today's 1080p HDTV home theaters.
The HDMI connections boast the latest 1.3 specification, meaning they pass a full 1080p video signal with 36-bit Deep Color for unsurpassed color reproduction on compatible TVs. Also supported, via Denon's newly developed Dynamic Discrete Surround Circuit-HD, are the new Dolby TrueHD and dts-HD Master Audio surround-sound formats now available on Blu-ray and HD DVD high-definition discs. And your existing 480p DVD collection will look better than ever with 1080p scaling provided by Faroudja's industry-standard-setting DCDi chip.
Ethernet connectivity, auto set-up, a new GUI and more
With an RJ-45 Ethernet port, the 3808CI makes it easier than ever to integrate you A/V system into your home network. Mac/PC audio streaming gives you access to Internet radio as well as all your digitized music, including MP3, WMA, WMA Lossless and now AAC-iTunes files! There are even USB ports (front and rear) with command and control functionality for portable music players, flash drives, and other devices. And of course the optional Denon dock lets you charge, control and distribute the music from your iPod.
This PC/network connectivity gives you the capability to make easy online firmware upgrades, and allows Denon engineers to remotely access your receiver and diagnose and fix many problems.
Another great feature is Audyssey MultEQ XT audio set-up, which tailors the receiver's settings for your room's specific acoustics from six different seating positions! And the new, truly interactive graphic user interface (GUI) for the onscreen set-up menus is much more attractive and intuitive, making it a snap to get your new receiver up and running and performing at its optimum levels.
The 3808CI is XM Radio-ready and Mini-Tuner compatible (with the XM Mini-Tuner and the proper dock, you can enjoy XM using your home audio system's buttons, knobs and display).
Multiple sources in multiple rooms!
With 3-source/3-zone capability and an additional remote control included, the 3808CI can easily be the centerpiece of your multi-room system. The RS-232 port allows integration with Denon's new two-way remote and RF/IR base station as well as third-party remote controllers.
Three independent transformers provide the juice for seven channels of 130WPC amplification, so you'll have more than enough pristine power to feed even the most demanding speakers. Denon's AL24+ processing reproduces low-level signals with optimum clarity to bring out all the delicate nuances of your music.
Highlights
* Plug n' Play functionality lets you enjoy your receiver right out of the box; there is still a broad range of assignable functions available for more advanced users and/or custom installers
* Dynamic Discrete Surround Circuit-HD for state-of-the-art reproduction of high-def disc soundtracks
* HDMI 1.3 repeater function passes the highest quality signals available
* AL24+ processing
* New GIU
* 3-source, 3-zone, Zone2 OSD, Zone remote
* Remote maintenance through Internet connection
* Wi-Fi Network audio and IP control
* 2-way RF remote ready
* XM Radio ready
DENON AVR-3808CI $1,599.00
Features and Specs
New front panel design, controls and lettering
Equal power amplifiers: 7-channel
Power output (watts per channel @ 8 ohms, 20hz to 20kHz): 130
All channels rated @ 0.05 THD
Low impedance drive capability
High-current/discrete amplifiers
Independent power transformers: 3
DSP Processors - Analog Devices, SHARC: ADSP 21366 x 1, 21367 x 1
Processor design: 32-bit floating point
Processor circuit sampling frequency: 192kHz
Dolby TrueHD and Dolby Digital+ Decoding, dts-HD Master Audio Decoding
THX Surround EX and Dolby Digital Surround EX decoding
Dolby Pro Logic IIx, with Cinema, Music and Game modes
dts ES Discrete 6.1 and dts ES Matrix 6.1 decoding
dts Neo:6 Stereo-to-Surround Cinema and Music modes
dts 96/24 5.1 for DVD-Video processing
HDCD Decoder
XM-HD 5.1 via Neural Surround decoding
Compressed Audio Restorer for portables/iPods/network audio
Audyssey MultiEQ XT auto setup calibration and room correction for 6 seating positions
Audyssey MultiEQ Pro calibration compatible - Audyssey Installer Ready
Auto setup microphone included: New Y/Alum type
AL24+ Processing on all channels
24-bit/192kHz DACs: 2-/8-channel PCM1791A
Analog-to-Digital conversion: 24/192 PCM1804
Variable High/Low Pass crossover points (12/24dB): 40/60/80/100/120/150/200/250
Assignable digital inputs
Digital input: DENON Link 3rd (PCM/DSD) compatible
iPod ready with a Denon D-dock
USB Port for portable music players/flash drives/HDD with command and control functionality
XM Satellite Radio ready - Mini-Tuner compatible
Multi-source/Zone discrete tuner select function - AM/FM/XM
HDMI 1.3a Repeater Inputs/Outputs - supports 1080p, 36-bit Deep Color, xvYCC Color Space, Auto Lip Sync correction, 7.1 uncompressed 24/96 Audio, SACD
Analog to HDMI Video Conversion/Scaling: 480p/720p/1080i/1080p
Faroudja DCDi Video Processing and Scaling (FLI02310)
Main Zone Video Encoder: Analog Devices ADV7320 12-bit
Main Zone Video Decoder: Analog Devices ADV7403 12-bit
NSV - Noise Shaped Video processing
Digital Inputs: 3 coaxial, 4 optical
Digital Outputs: 2 optical (assignable)
Digital-to-Analog REC Out
Analog Audio Inputs (including Tuner): 11
Phono Input
Analog Record Outputs: 3
Front Panel A/V Inputs w/Cover: Composite, S-Video and Optical
Independent Video Conversion: S-Video to Composite for Zone 2
Composite Video Inputs: 7
Composite Video Outputs: 3
S-Video Inputs: 7
S-Video Outputs: 3
Component Video Inputs x bandwidth (assignable): 3 x 100
Component Video Outputs (parallel main zone): 2
Discrete second zone Component Video Outputs
Dual surround mode speaker selector
All new Graphic User Interface (GUI)
RS-232 Port for third-party controllers and new Denon 2-way Remote Control and RF/IR Base Station
RJ-45 Ethernet Port: Third-party controllers, Mac/PC audio streaming, Internet radio and Web browser function, enhanced for WMA Lossless/AAC-iTunes and album art
PC setup and control capability via Ethernet
Remote/off-site diagnosis, correction, update and upgrade compatible
3-source, 3-zone capability
D/A conversion for multi-zone outputs (Optical, Coaxial and PCM signal only)
Discrete Multi-zone Video Outputs with OSD for Meta-data from iPod/XM/HD
Radio/Ethernet streaming: Composite
Enhanced Power Amplifier assign for multi-zone or bi-amping: 9 modes
Compatible with optional RC-7000/7001CI IR/RF 2-way Remote/Base Station
Dimensions (W x H x D): 17.1 x 6.7 x 16.9
Weight: 35.6
Discription:
* XM Radio ready
Highlights
* AL24+ processing
* New GIU
* XM Radio ready
Features and Specs
HDCD Decoder
Phono Input
S-Video Inputs: 7
S-Video Outputs: 3
Weight: 35.6
