Sorry that I can't directly answer your question directly, but just a thought that universals like Logitech Harmony or the Monster units really help simplify these types of issues. I decided pretty early on that the only way our new HT setup would work (particularly given the complexity of the 3808) was to have a simple to use way to run normal operations. I got a Harmony 880 and while you do have to program it, it's fairly easy to learn and works very well. The Logitech database even had entries for my almost 20yr old Denon DCM-777 CD changer.
My wife loves it and I haven't had one complaint about how complex or difficult to use the system is. You might want to think about this approach.
) When the replacement arrived and I got the same Connect Fail message, I was freaking out! With me though, I don't have a router, so I was connecting direct from modem to 3808. I was able to get Internet radio via Comcast w/o a problem but could never connect to the Denon server. I called Comcast, I called Denon, I posted here, no one at all knew how to solve the problem. One day I just searched the receiver forum here at AVS just fopr Comcast. Low and behold I found 2 old posts from guys down south talking about problems with Comcast. That's when I carried my receiver to my friend's house. I did call Denon and reported what I found out. I sure hope things are corrected cause I don't want to keep having to carry my 3808 to a friend to do updates
. i have a dvd-2930 connected via denon link and hdmi, and can only get cds to play in stereo, no 5.1, any ideas? when i watch tv, i can get 5.1 so i know the speakers are setup correctly, ran audessy, it found all my speakers. btw, this will be the first of many, many questions. thanks in advance.
